Unusual Delta DP 220 Drill Press
Maui
Upstate NY
Here are some photos of the Delta DP 220 that I just brought home in the trunk of my car. I've never seen one set up like this before. It has a very unusual head lift mechanism mounted on it that I haven't even figured out how to operate yet. Does anyone here recognize it? How do you use/adjust it? Is it meant to be a lift assist mechanism that takes some of the weight off of the operator when he adjusts the head to a different height? The belt cover is thick cast iron. This is probably one of the heaviest bench top drill presses I have ever owned.
driftpin
Look on the underside of the table and see if there's a date cast into it. Looks like the chain lift is to ease lifting the head, but I account for the height by moving the table. I sold my DP220.
Mohawk Dave
SoCal
When I was researching these DPs last year for my brother I saw a handful that had the chain lift. Super cool. Fastest way to find others/info is using Google Images.
jmarkwolf
Southeast Michigan
Maui
I believe that lift has a counter-weight inside the column which serves to simply "unweight" the head, making it easier to lift the head manually. The weight of the counter-weight will have to be overcome to lower the head. You might be able to attach the chain to the table as opposed to the head.
The column will have to be clean and shiny.
tarbellb
Oregon
where does the chain in the column go to?
any close up or detail pics would help
Packard V8
Spokane, WA
Yes, on the larger DPs, Delta offered a geared hand cranked lift mechanism to adjust the head on the column. It's pretty much impossible to get enough weight inside the column for that counterweight mechanism to move the head. It's designed to assist lifting the table.
And yes, with a rusty column, the counterweight is moot anyway.
jack vines
whateg01
doo dah, kansas, usa
jack vines
How does the weight that is in no way connected to the table assist in lifting the table? Where is the connection I'm not seeing?
slowtwitch73
Hellgate
Its for the head. I believe the chain is anchored in the column... where you can see the screw. There must be a chain reel in the head.
Would like some more pics.
tarbellb
Oregon
I bet the chain is disconnected and the top pulley has been rotated (accidently) to the front
Likely should be 180 degrees from current location to assist the table?
Dont think ive seen a consumer grade DP with a head lift mech?
Packard V8
Spokane, WA
Just thinking about it, the Delta 14" bench model in my shop was built in 1942. I don't believe the head unit has ever been raised or lowered in those eighty years.
On a production table, the head is the only moveable part, thus most were equipped with locking collars for the column, should the head need repositioning for a setup. However, on a bench model with the usual adjustable table, I'd have to think about why one would prefer to use the more involved and cumbersome operation to raise/lower the head.
jack vines
Maui
Upstate NY
Since there wasn't any other obvious way to do it, I simply loosened the head bolt and pulled upward to see what would happen. It was almost effortless raising the head! The pulley rotated as it took up the chain links, and when I let go the head stayed where I had positioned it. Here's a couple of pictures of the mechanism and the final head position. It's obvious from the shape of the slots that the cast iron pulley cover was designed to accommodate this head raising mechanism. Where I have it positioned now is the maximum height you can adjust it to. At any height I can still fully lift up on the pulley cover. This is a very slick design. I'm impressed!
Packard V8
Spokane, WA
Unusual, indeed. I've seen one or two which use a sash weight inside the column as a counterbalance for raising the table, but neverin sixty years have seen this option with a loooong spring inside the column to assist raising the head.
Been thinking about it all afternoon and still can't fathom why it is necessary to regularly raise/lower a bench model DP head.
jack vines
tarbellb
Oregon
Whoa
cool, thanks for posting the follow up photos. A interesting solution to that problem.
whateg01
jack vines
There are times I have had to use a block of wood or some other riser to position work at just the right height to fit a drill in the chuck and still be able to use all of the quill travel. There's a height where the table doesn't go low enough and the base is too low. If I would have lowered the head it would have let me do that now easily.
Maui
Upstate NY
I restore vintage machines and tools, and I can say with confidence that I am keeping this one for performing restoration work on other machines.
