niget2002
Josephine, TX
Used the mill and showed the son how to bore a hole through something.
Then broke the valve stem trying to reuse it. Probably should have just ordered replacements when I ordered the rim.
I don't have a way of cutting a larger key hole in the rim, so ground down the stock key a bit for now.
I'll order a new key and new tools in the future if it doesn't hold.
ZRX61
Solar Blight Valley, SoCal
Rode the ZRX11 today. Fan cycled on as I pulled into the garage, somewhat unusual (last time was a couple of years ago)... Altho with that said I was hauling *** on it & it was about 100deg today.
However, 7 hours later it's still hot(ish) to the touch. Probably need to investigate that.. which is a PITA as ya have to pull the tank off to get to the radiator cap. No sign of a coolant leak & the temp warning light didn't come on.
56vette461
Helped my son remove the faulty after market air bags on his Canyon. Once we had them off I pulled them apart. Pure trash. The mounting brackets were mismatched and mounting holes forced the bracket out of alignment with the frame. Truck drives/rides better.
rayra
Escaped from Los Angeles
Furniture assembly is going much slower than hoped. Working four pieces as a batch is naturally increasing the time involved, even as I save some setup time by doing like things in batches. But things are coming together steadily.
One of two matching bookcases getting its oak fascia before I pull it off the bench and assemble its twin.
I'm intending to get all four carcasses glued up, trued up and nailed off today and continue fascia and molding trim work tomorrow morning.
Two bookcases 55"H x 27"W x 11"D, with adjustable shelves, sitting atop an existing lateral file and a sideboard cabinet built to match that lateral and fill the rest of that wall. The sideboard roughly 28"H x 60"W x 18.5"D. The bookcases will flank a framed movie poster.
Last is a media cabinet for my parents, a thing of cubbies, records, VHS and other media, to facilitate my 'archivist' father's quest to digitize things. 34"H x 48"W x 14"D
all with adjustable shelves, oak-veneer plywood bodies, various oak fascias and trims.
I've got seven more cabinet, hutch, built-in storage bench projects to build after these, hopefully all before the end of the year. And some time in late September I get back to work on my huge masonry grill island project in the back yard, as well. Long days of splitting time ahead, same as the last 2yrs+
agent max
Tennessee
Well, today I finally got some stuff done on my 1991 Subaru that's been sitting for three years after my oldest daughter rear-ended it into a truck. Replaced the headlights, turn signals, grille, radiator, AC condenser, front bumper, bumper foam insert, bumper shroud, and various nuts and bolts that rusted in place :sad:
Then I got to cleaning up some of the 25 years of **** that've been sitting on the shelves and on the floor in various piles and boxes. Who knew you could accumulate so much, yet need so little of it?
Flat Thunder Channel
Punished various materials with the laser cutter. Made horrible stinks.
I plan to build a box around mine with either a fan blower or a port for a shop vac attachment. The idea is to port the exhaust out the window.
Today I had sporting events to attend for the kids. So far I only dug through my box of misc wires for some HVAC mods on the old furnace. Hope it works! 🙄
Not much, modified a bolt for a pair of snips that lacked a pivot bolt, small pair for my inside tools. Now to touch up the blades, (fairly sharp now, but...)
nadogail
Coronado, CA
When I pulled my Clamp on meter out of the case to change the battery, i found that the release lever on the clamp was broken. Looked up the Manufactures name and got a telephone number. Amprobe is now owned by Fluke; they don't offer service or a direct replacement product.
Made a trip to Home Depot and purchased LOCTITE Super Glue, waiting until tomorrow for the glue to cure before I reassemble the meter.
My serial number indicates the meter was manufactured in the late 1990's, a former employer purchased it for me.
Bill T
Easley,S.C.
Began playing with my newest "toy". Frame off restoration of a Triumph TR250. (Sorry for the poor photo. Still in my two-car garage, have not moved it into my shop yet.)
Swanny1953
Lucas, TX
Had periodic parasitic drain issue in '65 GTO, so took it to O'Reilly to get tested. Both alternator and voltage regulator are bad. Replacement on tap for today.
niget2002
Josephine, TX
Finished up my 2/4 drop.
Front: Maxtrac 2” drop struts and UCA’s
Rear: Timber Grove 4” drop CRM bags
IHC (geometry) axle relocation brackets
Spohn adjustable panhard bar
Hellwig adjustable sway bar links
That looks really nice. I was wanting to do something similar with my 1500, but looks like I'll be replacing the truck instead.
rayra
Rushed morning, starting with yet another trip to the big box hardware store for more expensive oak and more cheap beadboard. Got the rest of the 2nd bookcase box put together, both still need decorative moldings top and bottom. And I can't find the profile I want (and built for) on the bottom, to match the other two bookcases in my office. Not in wood, anyway. Very few choices. Am probably going to have to find a moulding store or better woods shop to find it, despite it being common in L.A.
Then my Goldbergian setup for truing up the middle support in its rabbet, in the sideboard. Probably won't get back to that until late this afternoon or early tomorrow morning. Have a couple medical procedures to head off to.
rayra
watch out, that's probably a bad 'upsell'. The alternator itself very rarely goes 'bad', it's little more than a metal case and metal windings / magnet set in resin. Any sort of parasitic drain is most likely with the regulator. Replace that and the pickup brushes, it's a very simple fix on older GM alternators. All you need is a nutdriver and a toothpick.
nadogail
Coronado, CA
Discovered that the damage to my AC/DC Clamp Meter is not economically repairable.
In my efforts to fix things, I succeeded in making the problem worse. I have been shopping on Amazon and found a replacement from an unknown company for about $50. If I didn’t want DC current and HZ I could get one for less.
As long as I am working with generators and batteries I feel that DC & HZ are important.
Arne73
2nd day working on the 8hp Briggs. Runs but has no governor response. Ran out of patience. Its gotta be something simple I've overlooked. A couple more items to check before I post a thread and consult the collected wisdom of GJ...
kaymccampbell
Upstate New York
Tore down the dryer. Rebuilt the control panel. Cleaned out the fuzz. Made a base and ablation plate for the laser cutter. Connected it to compressed air. Tested, tested, tested. Put the new watts link in Charlie's car. Kicked it out. Cleaned up. Put the Dingo, Burg, n big boxes back inside. Started the cutter cutting out a xmas tree.
ZRX61
Pulled the (plastic) chain guard off the ZX11 & cleaned out 27 years of snarge. One of the three bolts is a pisser to get to.
Got most of it sorted, but it still needs some work.
Cleaned up some parts of the swingarm I couldn't get to with the guard in place. There's quite a bit more cleaning to do when I have the wheel out.
Did a bit more polishing on the rear wheel.
It's *almost* where I want it. There are very fine lines on it from the original machining & I like the look of those. If I took the wheel to a pro polishing shop those lines would disappear so that's not an option.
Heat stopped play.
oh, also bought home my "garage trash can" from the storage unit. It was one of Doug Chandler's (13gal) fuel cans at Willow Springs when he had the #1 plate on the factory Kawasaki 750. I cut the top off it. There's another unmodified can in the storage unit.
In other news, got a call late yesterday that all my recent biopsies came back clear :)
cjcocn
Manitoba, Canada
Installed the new clutch on my Pro Drive mud motor and got some space back.
Enough projects are done so that I can bring in my diesel and do the cab corners, swap out the bed, and install some sound dampening and sound insulating material.
Finally.
Almost nothing: Painted a can with black lacquer for adding to the center "console" board in the DD Samurai to hold a SS insulated water bottle; so it will have 2 std drink holders, and this over sized one...
Old Man Roger
Palm Coast Florida
Heat stopped play.
Congrats on the biopsies.
56vette461
Our church is refurbishing a former classroom for use as a Community Room for students and their families. Started building shelf supports and refinishing shelves in the shop Easier to work here than in the parking lot of the school.School starts on Thursday.
Cleaned up the mess I made earlier and stowed all the misc wires back in the original bin and shoved it back in the cabinet.
I got a little ambitious with the few minutes of free time I had and cleaned up a few other areas of the workbench. Lots of miscellaneous tools needed wiped down and put away. Small victory 👍
todras
Completed my vehicle wash station this past weekend. Came in around $300 for everything.
Made this bracket out of a piece of oak I had lying around.
Corretic Pressure Washer Hose... https://www.amazon.com/dp/B09YH5GPLJ/?tag=atomicindus08-20
General Pump D30002 3/8" x 100' Steel Hose Reel with Swivel Arm and Mounting Bracket, 4000 PSI https://www.amazon.com/dp/B00INY1V4Y/ref=cm_sw_r_apa_i_5QX853G5HQQA581HAZCS_0?_encoding=UTF8&psc=1
Twinkle Star Pressure Washer... https://www.amazon.com/dp/B07MY17MGX/?tag=atomicindus08-20
Tool Daily Foam Cannon with 1/4... https://www.amazon.com/dp/B07HC898GM/?tag=atomicindus08-20
Sooprinse High Pressure Washer... https://www.amazon.com/dp/B07KPVM5MS/?tag=atomicindus08-20
The SS shelf I found locally for $30 but here is one similar. Metal Shelf | Stainless Steel Wall Mount NSF Shelving for Commercial Restaurant, Kitchen, Laundry Room, Food Truck https://www.amazon.com/dp/B08WWV1SXR/?tag=atomicindus08-20
6' black hose https://www.tractorsupply.com/tsc/product/groundwork-6-ft-x-5-8-in-leader-hose-black
I had to buy fittings at HD & Lowes that weren't in the coupling kit listed above.
90 degree elbow since my shelf was a little small for the pressure washer. Had to install this to the back so the hose would fit.
(1) 3/8 to 3/8 FIP.
(2) 3/8- IN M X M-22 M adapter
Bob Heine
Boca Raton, Florida
todras
@todras, welcome to the Garage Journal! Nice wash station setup, especially for the price.
You might want to add another gun to your setup. Using that cannon attachment on the end of your full size wand makes it a challenge to get to tight spots.
Amazon has reasonably priced guns:
Thanks brotatoe chip! I have this one. There are so many links in my post you prob missed it.
