Holy smokes. I'm no electrician but it seems like there's a lot of directions everyone is sending this guy lol. My cousin is a license electrician up in mass. He could prob figure this thing out. You're going from 3 electrified wires to 2 right? How come you can't hook up 3 wires into one wire for one side of each element and 3 wires into one wire for the other electrified wire for the other side of each element?
LOL...yeah...there is some conflicting wiring on the transformer but I think if we are using the diagram that I supplied from the manufacture of the my transformer I think it's hooked up right.
So...the wire in the power cable is 8 gauge, the plug says 6-8 gauge for 50 amps...so I wired it up but not to the kiln just yet.
I checked the voltage on my panel, I put the multimeter to the ACV 600 setting and then touched each probe to each side of the panel where the breakers go and I get 252 to about 260. It fluctuates back and forth.
Now on my transformer and plug wiring, before I plug it in and check the power, I put my meter on continuity check and ground to ground went to zero and ground to black and red did nothing.
Then red to black goes to zero...is that right? From the wiring diagram I guess it kind of makes sense but not sure if it's supposed to do that...like maybe something is crossed.
