White Shadow
- Joined
- Jan 26, 2014
- Messages
- 985
I have a 22kw Generac stand-by generator. I also have two HVAC units that use ECM fan motors. My understanding is that ECM motors already somewhat "soft start" compared to traditional fan motors. However, I noticed the other day that my generator significantly dropped RPM when the A/C kicked on. One A/C unit was already running and when the second unit kicked on is when I noticed a big change in the generator's RPM. The generator also started surging, so I turned off the that second A/C unit, but the surging continued anyway.
So two questions:
1- Does it make sense to install a soft start on my A/C units even if I already have an ECM fan motor? Would the soft start help with the compressor? I'm thinking that's the big power draw that's causing the RPMs to drop during start-up.
2- Is there an issue with my generator since it continued surging even after I shut off one of the A/C units? When utility power was restored, I restarted the generator and it ran smoothly again. So I'm pretty sure the surging was due to the load at the time or at least the start-up load from the A/C unit.
So two questions:
