So my clothes dryer has a valve that allows it to spray water into the drum. Seems counterintuitive. This valve failed, I shut off the water, ordered the part and today I went to install it. Two screws to take the top of the dryer off and the valve is right there. Unfortunately, the screws that hold the valve in place go in from the back and are behind the back panel which has a ton of screws. Removed 15 or so of the back panel screws enough to pull it away a bit and get to the valve screws with a 1/4" ractchet with a 1/4" socket with a 1/4" hex tool. The problem is the tool isnt retained so there was a high chance of it slipping out and falling into an inaccessable part of the dryer.
I had these two tools on the "things I want" list
zoro has something that might be similar: https://www.zoro.com/general-single...5/i/G2284493/?recommended=true#specifications
What is this style of tool called? Recommendations on brands?
Thanks.
5575 Master Screwdriver Set | Chapman MFG
5575 is Chapman’s most complete precision screwdriver set total 56 pieces with 51 insert bits which include Slotted bits, Phillips bits, Metric and SAE Hex Bits, and Star bits which fit Torx screws. Over 300 tool combinations! Machined from USA steel with a black oxide rust inhibitor finish...
chapmanmfg.com
Thanks.
