Cordless vacs are now a thing too. Plus not everyone uses them with a vac I don't generally bother when I am outdoorsI have a Fe$$$$tool. Great for breaking down sheet goods and awesome dust collection. I picked Festool over others for the better dust collection.
I don't get the battery powered concept - I always have it attached to a vac so why no cord? Granted, I bought it before cordless track saws were available. I do have a Milwaukee M18 battery saw but only use it outside the shop for "rough" cuts.
I bought the Wen clamps too@glennm depending on how much you're planning to spend, and how often you plan to use it, I went cheap and bought the 6-1/2" Benchmark corded track saw from Home Hardware. I've been very impressed so far. It's a $250 kit but I got it on sale for $200 with four sections of 27" track, two (junk) clamps, track bag and saw bag.
Upgrade the track clamps (I grabbed some made by WEN off of Amazon) and you'll still have money for a few sheets of plywood to actually use it on.
Cheers,
Not to sidetrack the thread, but @Firebrick43 can you elaborate on the parallelogram comment? What do you mean by this?Also the dewalt saw is a parallelogram instead of just pivoting like the others which is very nice.
Instead of just a pivot point in the back like all the other saws, it has 4 links with bearings in each end. It actually only has 3 pieces as 2 of the links are cast together in one piece. The saw handle/blade always stays level and moves in an arc never changing angle of attack. I don't care for the pivoting motion of the others and how your wrist moves. Its very similar to a 4 link suspension. Well except the double cast together only allows movement in the arc and no pivoting axially in the motor shaft axis.Not to sidetrack the thread, but @Firebrick43 can you elaborate on the parallelogram comment? What do you mean by this?
TIA
I have quite a few friends with or should I say had TS55's Most have all burned them up and have makitas now as they are the same trackI originally had a Corded Festool TS55, I ended up cooking the motor cutting 1 1/2" MDF. I blame it on "dirty" power. I work in the studios and everything is run through spider boxes etc. Festool repaired it for free, and I sold it and bought the TSC 55. The Cordless has more power than the corded since it is an updated motor. I have been using the cordless for 4-5 years now and love it. The Makita is a decent saw, I'm not a big fan of the Dewalt. Milwaukee will be releasing a cordless track saw in the next couple of months if your on that battery platform.
My grizzly has a riving knife as well, but unfortunately it is discontinuedI bought the Kreg this year. The riving knife sets it apart from anything else in its price range.
Unfortunately, the pivot is a bit wobbly, allowing the blade to wander as much as 1/8". I came up with my own fix, but the idea that they'd ship it this loose does still bother me.
I guess it all depends on what you are cutting. My table saw has a riving knife and it's a good feature. Me personally, I don't see a need for one on a track saw. I'm cutting almost all sheet goods, plywood, osb, faced ply, MDO, etc. These woods are very stable and with the track guiding the saw it's very hard to get the blade in a bind. Also if a blade were to bind and the saw come out of the wood the saw blade goes into it's shell automatically. So personally I don't see the need for a riving knife on a track saw. Now if I was cutting some unstable woods like slabs and other stuff that has a tendency to release tension as you cut it then a riving knife might be more important. But for breaking down stable sheet goods I would not put that feature at the top of my list. But everyone's situation is different.I bought the Kreg this year. The riving knife sets it apart from anything else in its price range.
Well put. My TS55 has a riving blade, but I don’t see that as an advantage on sheet goods, which is all I use it for. My unisaw is still queen of the shop.I guess it all depends on what you are cutting. My table saw has a riving knife and it's a good feature. Me personally, I don't see a need for one on a track saw. I'm cutting almost all sheet goods, plywood, osb, faced ply, MDO, etc. These woods are very stable and with the track guiding the saw it's very hard to get the blade in a bind. Also if a blade were to bind and the saw come out of the wood the saw blade goes into it's shell automatically. So personally I don't see the need for a riving knife on a track saw. Now if I was cutting some unstable woods like slabs and other stuff that has a tendency to release tension as you cut it then a riving knife might be more important. But for breaking down stable sheet goods I would not put that feature at the top of my list. But everyone's situation is different.
I also use mine mostly for sheet goods and stuff like cutting doors, so it's often not mounted on my saw. But I have used it to make rip cuts in dimensional lumber where precision was important and I can't take the work to my table saw.I guess it all depends on what you are cutting. My table saw has a riving knife and it's a good feature. Me personally, I don't see a need for one on a track saw. I'm cutting almost all sheet goods, plywood, osb, faced ply, MDO, etc. These woods are very stable and with the track guiding the saw it's very hard to get the blade in a bind. Also if a blade were to bind and the saw come out of the wood the saw blade goes into it's shell automatically. So personally I don't see the need for a riving knife on a track saw. Now if I was cutting some unstable woods like slabs and other stuff that has a tendency to release tension as you cut it then a riving knife might be more important. But for breaking down stable sheet goods I would not put that feature at the top of my list. But everyone's situation is different.
Wow, lots of great advice here. I see that the Festool is highly rated and the corded model is on clearance right now. I also noticed that the Festool long track is very expensive. Makita, not so much. I like the sound of the Milwaukee, I do have a bit of an investment in their tools. Is there any info on it yet?
@rlitman - Can you elaborate on this? I have the Kreg as well but have not used it yet. Curious about this potential issue.I bought the Kreg this year. The riving knife sets it apart from anything else in its price range.
The riving knife screwed me a couple times when I have tried to plunge into sheet goods
Nice to have, not critical, IMO
Grizzly. My whole setup cost as much as the 1900mm Festool track, so I'm OK with the trade offWhich saw do you have? The riving knife on the Festool is spring loaded (except on very old models) and retracts (gets pushed up) into the housing if there is no kerf for it to slip into, such as the start of a plunge cut.
Riving knife is good to have on the track saw when ripping solid wood.
Seth
This will be the main use for me. We have a bandsaw mill and plenty of live edge lumber. I’m getting tired of trying to cut straight edges on the table sawIs there a tracksaw without a riving knife? All the major ones do.
I use mine a lot to "cut out" boards out of rough hardwood lumber. I get logs milled with a woodmizer and air dry. Since they are just stabbed they are usually 24 plus inches across and have checks usually down the center. Most of the time defects, checks, and grain direction means that several boards can be marked out. Many times these are not straight with the board, may be 15 degrees or so off for max yield. . I lay my 55" track and cut to my chalk lines. That edge is now pretty much jointed. May have to take one pass just to square it up to the face after jointing/planing it but much easier than any other method.
I have had some wide wild cherry that would of had terrible waste if it wasn't for the track saw.
This Amazon reviewer summed it before I bought mine, so I knew what to look for:@rlitman - Can you elaborate on this? I have the Kreg as well but have not used it yet. Curious about this potential issue.
Thanks.
The Kreg riving knife is retractable too.Which saw do you have? The riving knife on the Festool is spring loaded (except on very old models) and retracts (gets pushed up) into the housing if there is no kerf for it to slip into, such as the start of a plunge cut.
Seth
Most do not. Makita, Bosch, even some Mafell don't. Neither do the minor players like Wen or Grizzly.Is there a tracksaw without a riving knife? All the major ones do...
