Got a huge problem. Electrician was running new line today, got tangled up in my DSL lines. He pulled the data lines coming from the Frontier equipment loose from the input side of the phone jack. He also pulled the RJ11 that was plugged into the phone ******** of the cable going to the modem. Frontier says they can't attend for nearly 3 weeks. I can't wait that long because it handles my some medical monitoring equipment, so I can't go 3 weeks with no service. Hoping someone on here can help me out.
The signal coming from the Frontier equipment to the phone jack is on the Blue pair and the Orange pair. The phone jack connections are color coded, so I think I'm okay there. The color code on the DSL cable from the phone jack to the modem is also on the Blue pair and the Orange pair with a RJ11 on each end. I reconnected everything maintaining the color code throughout and installed a new RJ11 on the DSL cable, but I had 3 fault lamps (Internet Connectivity and both Broadband channels). Then I tried a new phone cable I purchased at Walmart and got no change. I found it wouldn't even pass on the network cable tester I have. So I tried remaking the DSL cable completely and while it tested good in my network cable tester, it still gave me 3 faults, but after a 2nd attempt at remaking the DSL Cable I got it down to only 1 error light. The modem indicates I have good internet and Frontier says they show my internet is working, but it won't connect and they will not provide any further information. The modem is an Arris NVG4438, which I am not familiar with. If anyone has any knowledge oof this modem or any suggestions I would be most appreciative.
My fear now is the data cable between the Frontier equipment and the phone jack may be damaged.
