GrantCee
Other than the KTC, the only other roto head I've used and can compare it to is the S-K. The Ko-ken head is smaller than the S-K in diameter and thickness by a few millimeters, so from my standpoint it's smaller than what I've been using. Like the S-K, I have no doubt it will take as much torque as I'm able to apply to it.Hey, do you find the Ko-Ken 3/8 roto to be wide & thick headed? I also think it's on the heavy side. It's built like a tank, just not my favorite roto head.
As to weight, it's definitely heavier than the S-K. That's due to the slightly longer handle and the much thicker grip area. It's very back-heavy; I'd prefer if they'd hollow out the grip area to reduce that weight. Then I'd probably complain it was front-heavy,
For some things I can see where it might be too big, but that's why I also got the KTC!
I have the ZEAL flex heads, which to me are very small. But I also don't like flex heads, so...I think the Ko-Ken flex heads are thick headed too just like Nepros. maybe it's a Japanese thing. The best thing about Ko-Kens is their low back drag but, I find myself reaching past the Ko-Kens for MATCO, Tekton, and Carlyle flex heads.![]()
I have that same ratchet, and I agree about the handle. I've never liked that general profile, though, so even if it were larger in diameter and longer I'd still not like it.I picked up the longish KTC 3/8 drive roto head BRSW8L from DRPD tools and think the handle portion is too short and the tapered portion tapers too much, too narrow on the end. The handle section needs to be at least an inch longer and the taper not as narrow. I know this is just my opinion and that it may fit other people's hand perfectly. Still a Great ratchet though.![]()
But, as I said, that tiny head and longer reach is worth putting up with the handle. If they ever release one with a more Ko-ken like handle, I'd probably buy it.
I'm very reluctant to apply the same amount of torque to it as I do the Ko-ken, though, simply because it's smaller in every dimension. As someone noted, it's really a 3/8 in a 1/4 body.
