Some Old Fasteners
cannuck
Rural SK
I have had my "day tank" inside of a tensioned fabric storage shelter on my best bud's farm for last 20 or so years, but he has been offered to swap that farm for the land surrounding his home acerage and we need to get things into "saleable" presentation. I have a large horizontal tank on one side and a "small" (6,500 USG) vertical on the other side that we use for farm fuel. First problem was that we put this stuff inside when we were 20 years younger and had a 10,000 lb. telehandler on hand. Had to lay the vertical down, so firsts had to skid it into the center of the floor. It had sunk about 3/16" into the asphalt over the years, so a lot of jacking and shimming before using 9k winch on my chore truck to skid it in place. To lay it down, I build a bracket to bolt onto the top, central lid using exising holes. When I went up to measure, I found that it still had the original fasteners from probably 70 years ago - and even at that done with pre-war hardware. It used square bolt heads and square nuts. When I called for a 3/4 AND a 13/16, but buddy thought I was nuts (yeah, that' a fastener pun). Had to explain to him that going way back into the last century, people couldn't afford duplicate tools so fasteners used one size for the bolt and next size up for the nut. Have seen it once in a while with hex but almost always with square...but have to admit it has been quite a while since I last removed square headed fasteners at all. Helps explain why there are still some 8 point socket sets around in the vintage tool world (and I don't have them up to that size).
Just in case anyone was wondering: used truck winch to pull the tank over, catching it with a 2 ton chain block on a trolley on monorail track in middle of building. The electric winch was too light to do this safely, thus the heavier chain fall. Once we got it leaning against the back of trailer used 6k forklift to pick up the base and skid it fully onto the deck. Offloading on other end was with my mobile crane, spreader and basketing slings. Not sure how/when/where I will put it back in service as my yard is still very much under development.
Zeke
Thank you for the explanation of "next size up." I never questioned it but now I know. For instance, in my bin of 5/16ths bolts and nuts there are a few nuts that are 9/16ths instead of the machine bolt size of 1/2. I just accepted them w/o questioning them.
And it does make it handy to use 2 different wrenches sometimes when I'd normally use a socket and a wrench for the difference. I will mention that I have duplicate wrenches but they are stored as sets and sometimes not in the same place.
I keep a limited selection of square head bolts and lags because sometimes in my work that's the original fastener.
Pen & Wrench
Huron, SD
I've noticed that too when I've taken really old stuff apart, the bolts and nuts were different sizes too. I loved the pun, I almost bolted into laughter!
C
cannuck
Rural SK
Thinking about this thread, I seem to remember the odd time encountering M13 bolt heads with M14 nuts on '50s VW.
jh87
Indiana
I was working on a drill press we have at work and it was like that. The bolts were a 9/16 and the nuts were a 1/2. Interesting stuff. Another thing is I have some old wrenches, and instead of being marked with the actual size of the opening, they’re marked with the diameter of the bolt they fit. For example, the wrench might be marked “1/2” but it’s actually a 3/4 wrench. Probably made sense at the time, but a bit confusing now.
gorilla
Those wrenches are probably British. I believe that's the witworth standard.
TractorJeff
Elkhorn, WI
QUOTE: "For example, the wrench might be marked “1/2” but it’s actually a 3/4 wrench"
I got a whole bunch of these from a Navy Surplus Sale one time.
Don't know whatever became of them?
As far as Vintage Fasteners, if they are old enough, they unscrew, no matter how rusty.
I always figured Virgin Iron made that Steel, not this Recycled/Blended stuff now.
PZ 1
Larger nuts called heavy nuts are used when more strength is needed. A 5/16 heavy nut takes a 9/16 wrench.
Today a 7/16 bolt takes a 5/8 wrench while a standard 7/16 nut takes an 11/16 wrench.
I wonder about the wrench explanation for the two different sizes.
