what is it
M Mr_fixit Well-known member Joined May 24, 2008 Messages 1,221 Location Rustylvania Aug 26, 2022 #1 what is it
OP M Mr_fixit Well-known member Joined May 24, 2008 Messages 1,221 Location Rustylvania Aug 26, 2022 #2 it looks like a big version of something I might put on a fiberglass fish rod for running wires over insulation.
S Skooterj Well-known member Joined Mar 11, 2021 Messages 750 Location Indiana Aug 26, 2022 #3 DIY Wind Turbine?
P PCustoms Well-known member Joined Jul 23, 2011 Messages 22,809 Location VT Aug 26, 2022 #4 A good example of why you don't use pvc for airlines
S Sawlog Well-known member Joined Aug 5, 2020 Messages 69 Location Illinois Aug 26, 2022 #5 It’s for a water well. You run your pump line through the middle and then drop your pump down the well. They keep the pump line from rubbing the side of the steal casing and wearing a hole in it.
T tdcisco1 Well-known member Joined Jan 15, 2016 Messages 276 Location western pa. Aug 26, 2022 #6 Proper name is a centralizer
R rayra Well-known member Joined Dec 1, 2014 Messages 4,724 Location Escaped from Los Angeles Aug 26, 2022 #7 Elmer Fudd's blunderbuss, after Bugs stuck his carrot in it. /besides, everybody knows you use the WHITE PVC for air conduit
OP M Mr_fixit Well-known member Joined May 24, 2008 Messages 1,221 Location Rustylvania Aug 27, 2022 #8 rayra said: Elmer Fudd's blunderbuss, after Bugs stuck his carrot in it. /besides, everybody knows you use the WHITE PVC for air conduit Click to expand... white or grey, either for air conduit.
