Wrench97
I could see the lower ones having a issue with heat causing them to loosen up, even loctite will not hold up to heat cycling.
Thanks, no sealer yet.Nice. Do you have any kind of sealer on that pristine floor? Be a shame to stain it up.
Or duct tapeI'd be sorely tempted to drill/tap that boss and put a cover plate over it.
Best Wishes for a Comfortable and Speedy recovery.Not a thing: Worked from 5AM to 8:30 and then had umbilical hernia surgery - I've been "sleeping it off" most of the day - "it" being the general anesthesia...
JEEZUS! I know you said a louder horn, but that’s got a compressor…..lol You‘re gonna be like that guy in the dually with the train horns..lolPulled the left side lower fairing off the ZX, then the gastank & inner fairing doodad. Horn wouldn't fit on the right side as a radiator hose was in the way a bit. Horn fits the same place on the left side. Mocked it up to make sure it cleans the fairing & the radiator etc.
Then had to come up with a location for the compressor. It will fit under the gastank by the battery...
Or next to the left intake snorkle, but they will require installing a couple of rivnuts in the frame & I'd rather not drill holes in the frame.
Need to cut this half-assed mount off the compressor as it will be mounted with Adel clamps...
Stupid stuff lol. Hate when they don’t give me Subaru to work on. Everything I did was a Subaru except an Enterprise Rental Vehicle oil change on a Ford Expedition. Ford tech was too good to do it he said and only done the recalls. I ended up tearing the antenna fin off with my lift. I have an old lift like from the 80s that has the wire at the top that hangs low and the fin got caught on it coming down. It made a heck of a pop and flew off after it drug the wire down with it lol. We just glued it back on and sent it. The car was a 2021 with 49,000 miles in rough shape was leaking oil like a sieve. The radio and everything still worked we literally just glued it back on and made sure everything was right and tight. I didn’t necessarily want to do that but it wasn’t me that did lol my manager did. They were coming to pick it up anyway, I don’t understand why one of their techs could not have done it. I’m just glad they know it’s not my fault. My lift is the only one like that. Other than that nothing bad happened lol
except one of my training boys having a Tahoe towed back for only putting 6 quarts in. I wrote him up for that cause he was supposed to check the level before it left just like every car. 2 more and he is gone. I’ve given him a lot of leeway already so I decided I needed to take corrective action I have the ability too even though I’m not technically a manager. People were on vacation so tow truck driver had to travel a good distance to get them. The light didn’t come on till they got going down the road.
Heal fast.Not a thing: Worked from 5AM to 8:30 and then had umbilical hernia surgery - I've been "sleeping it off" most of the day - "it" being the general anesthesia...
Vicodin or Tramadol are you friend.... Hope you heal quickly.Not a thing: Worked from 5AM to 8:30 and then had umbilical hernia surgery - I've been "sleeping it off" most of the day - "it" being the general anesthesia...
I don’t really think it’s funny. Everyone knows I use that for everything lol. I wanted to get them a new one but we glued it. Not my idea. But I’m not going to fault anyone for it. It breaking wasn’t my fault so I won’t hold against them for the repair either. If enterprise had one of their techs fix it they could of paid for it not us but their equipment is probably a lot newer so they would not have had this issue. I don’t think it’s funny but the words everyone yelled when they heard it was.I don't understand. Sounds like your shop did a half-assed repair on a customer vehicle for something you broke and you have laughing emoji's when you describe it?
I had a newly installed flapper leak in the past.Toilet tank leak test for the last 18 hours. Put the guts from the other tank in this new/old one and the flush valve rubber did not conform well so the water came out as a constant stream. Same for the flapper which was maybe 3 years old and still pretty pliable. Hit up the home store for new internals and it sealed up properly. There is a small bit of water dripping from the flapper but of insignificant quantity, one drop over 8 hours and about 2 drops when I checked it the next morning.
The setback on this tank is different than the old one so it does not sit on the bowl mounts. Cut phenolic as spacers for that.
More like "European sports car" horn, but @ 120Db.JEEZUS! I know you said a louder horn, but that’s got a compressor…..lol You‘re gonna be like that guy in the dually with the train horns..lol
