cutting reinforcing mesh
billconner
Thousand Islands NYS
Will the HF 8" bolt cutters suffice for cutting 10 guage wire mesh? There only $9. or the 12", 18", or 24"? Or should I just use my 5" grinder I've been cutting no. 4 rebar with? I've not cut mesh before and trying to guess what is easy and quick. And don't expect to ever do it again
GeoBruin
I think the bolt cutters will work great. If you have a lot of it to cut, it could get tiresome, but for a reasonable number of cuts, it's probably the simplest thing.
I just bought a HKP 24" pair used, was cutting the equivalent mesh no problem. The head was a bit big for a few cuts. Maybe step up a size to 12".
I prefer to not create sparks if I don't need to, I'm not in that much of a hurry to complete too many jobs. Now if you have a few hundred cuts to make, maybe.
KnurledNut
n/a
I just did a job cutting this stuff and used my 8" Knipex mini bolt cutters (w/notch). Effortless and fast.
Any of the similar knockoffs will do fine.
On the big slab jobs ive helped with we rolled the welded wire mesh on the ground and cut it with long bolt cutters to keep from bending over so far. (Not that concrete workers have any back problems or anything. :lol:)
Longer handles means more leverage, which means less work. As Knurled Nut said, if you can reduce bending....
I'd get the biggest reasonable ones, for the "next job". I've gotten by with 12" for a long time, so when I could get 24" cheap, all over it.
