Switch Recommendations
nitroracer20
NY
Hi - i need a replacement switch for an enclosed trailer motorized tongue wheel.
I attached some photos of the current broken switch.
Please, if anyone has an amazon or similar equivalent it is much appreciated!
Thank you senseis!
mike93lx
Richmond, VA
AA/FC
I have purchased that exact switch in the past from Home Depot.... I'm not saying they still stock that same switch today but they did at one point several years ago. It's worth a shot....
Edit:
I assume your switch is momentary spring centered, correct?
The switch below is very similar but it's not spring centered. You would need to manually switch it back to the centered position, otherwise it would stay switched in either direction. Depending how quick you need it, this would probably get you by until the correct switch can be ordered.
Apparently HD no longer stocks the momentary version of this switch.
Edit again: (lol)
I don't know where you live, or what stores are near you, but I just looked and my local ACE Hardware store has the correct switch in stock.
N
nitroracer20
NY
Tight fit, but got the trailer in!
