Some quick photos I took earlier on lunch, this time pliers.
Tsunoda CP200 JIS:
Basic JIS linemans pliers in a larger size. I like my other Tsunoda stuff and these seem well-made too. Hinge is a little stiff out of the package but I'm sure I can get it to loosen up. One neat feature is that the inside flats on the handle side of the fulcrum are grooved/ribbed as well so you could squeeze something like a nutcracker.
TOP BN-200:
Veeerry similar in shape and form factor to a vintage Crescent (USA) pair that I have except the jaws are obviously offset. But hey, if it's not broken, don't fix it. These should come in handy for grabbing things that are up against flats (like fittings on the firewall of a car or plumping coming out of a wall in a building). The texture is a coarse powdery feeling matte finish with ribbed grooves on the outsides of the handles and a brushed grind on the sides of the jaws.
Tsunoda KBN150:
These are pretty cool, it's basically a pair of pliers and offset flush-cut nippers all in one. Designed as a zip-tie installation tool, the section of the jaws closer to the handle is not actually a blade but a rib jawed squeezing tool. It's meant to pull zip-ties tight before you snip them off with the blade closer to the tip of the jaws. These would be great for any AV tech or automotive accessory installer. At work, I occasionally stitch zip ties through cardboard boxes to help secure very heavy objects for shipping (vs using a ton of packing tape), so I got a second pair to leave at my desk there.
Engineer PZ-58:
My first extraction pliers, these are the Neji-Saurus PZ-58. They come in a few colors but of course I chose the pink ones. Mine also came with a tiny little bottle of what I believe is a combo penetrating fluid/rust neutralizer (not pictured). While the handles look sharp or uncomfortable in pictures, it actually feels like a soft-touch silicone.. Not super squishy but definitely comfortable and grippy in the hand. The spring loaded action feels very smooth and the dino-head cap (there is a different cute face on each side) fits snuggly for keeping in a box. Interestingly, the jaws further out past the cutting blades do not actually meet and leave a small gap when the pliers are closed all the way. I'm sure these will come in handy at some point down the line, I just wish I had them back when I was using phillips drivers on JIS fasteners.
