Ko-Ken would probably be my first choice but I’m having a really hard time finding a 1/4 drive roto head from them.I believe KTC, Vessel, and Ko-Ken all have options.
What is the white part on the bottom of the handle, as in does it serve any purpose or just cosmetic? Mine doesn't have that. I didn't know there were other models.
Actually looking into it, I think the Ko-Ken and KTC might just come in 3/8" drive. Vessel definitely has a 1/4" model though, available both on it's own and as part of a set:Ko-Ken would probably be my first choice but I’m having a really hard time finding a 1/4 drive roto head from them.
I wasn't actually aware when I bought them either. Good to see atleast some of their hammers are still made in Japan.What is the white part on the bottom of the handle, as in does it serve any purpose or just cosmetic? Mine doesn't have that. I didn't know there were other models.
Not that it really matters to me but the one I got says made in Japan.
Yes, I “see the light” with regard to these.
Up until about 5 years back I never owned one of these. Didn’t see the point. Then I got a Snappy on a deal, and it became my most used tool.
Think they are just about perfect for all those 8 / 10 / 13 mm fasteners that I’m working on all the time.
Very tempted by the Nepros.
That’s interesting.
L to R, PBSwiss 3mm, Nepros 2.5mm, Snapon 2.5mm, Snapon 2mm, Nepros 2mm, Snapon T25, Nepros T25.
I've also been testing some of the Nepros hex sockets along side my PB Swiss and Snapon ones, and they are quickly becoming favorites. I dont know if I like them better than PBSwiss, but they do seem to be on par, plus they make some sizes and drive combinations that I need that PB Swiss doesn't. I'm not a fan of the Snapon hex or Torx sockets at all, but haven't found a better brand for inch sizes yet.
That’s interesting.
I too like the PB Swiss, but I think they are discontinued.
Have you tried KoKen for hex bits? They are pretty much my “go to” now for hex and torx bits, and they offer inch sized bits.
The “new kid on the block” seems to be Wera. They offer a huge selection of hex and Torx bits in different lenghts and different drive sizes. I think the “socket” parts are made in Taiwan, the “bit” part in the Czech Republic.
Haven’t used these enough to determine how they hold up, but early indications are good. I like the colour coding, and also the cases they come in. These are long 1/4” drive. They also have the “holding function”.![]()
I also had the same experience with the set of the Wera's I owned and immediately sold them. Was not a fan!The only good thing about those Wera sets is the pouch organizers. I used to have those in both long and sort lengths. The ball detent HF function makes them weak. I broke/deformed multiple 6mm working on bicycles. Also, they mar fasteners. If you use the hex HF ones on painted bolts it will leave a scar. The torx fit to fasteners leave something to be desired.
They are still available for sale, but not easy to find. So far they are the best that I have found. Just wish they made some SAE sizes and more of their range in ¼ drive.I too like the PB Swiss, but I think they are discontinued.
There are very few Wera tools I like, but their Hex Plus stuff is one of the few things I do like. I haven't damaged any internal hex screw ever since I started using them. This is the first time I see any complaints. I only have a set of stainless L-keys with ball ends and no holding function tho.I agree with the above...not a fan of Wera's hex/torx stuff.
The color-coding/cases are nice (and I really like the sleeves on the L-keys), but that's about it . The holding function is annoying, and the Hex-Plus is too extreme and just ends up damaging everything that they touch. Especially on the smaller sizes.
To be honest, that was my concern, but I thought I’d give them a try. There are applications where the holding function is useful. They have been o.k. so far, but I haven’t applied a load of torque to them yet.The only good thing about those Wera sets is the pouch organizers. I used to have those in both long and sort lengths. The ball detent HF function makes them weak. I broke/deformed multiple 6mm working on bicycles. Also, they mar fasteners. If you use the hex HF ones on painted bolts it will leave a scar. The torx fit to fasteners leave something to be desired.
Why not a fan?... I'm not a fan of the Snapon hex or Torx sockets at all, but haven't found a better brand for inch sizes yet...
I have a set of their stainless L keys in Hex Plus. Save them for removing fasteners where someone rounded the heads. Often times they will get out what nothing else will, but I agree too aggressive for daily use.There are very few Wera tools I like, but their Hex Plus stuff is one of the few things I do like. I haven't damaged any internal hex screw ever since I started using them. This is the first time I see any complaints. I only have a set of stainless L-keys with ball ends and no holding function tho.
agreed 100%. After testing the Nepros I’ll be buying more to fill in around my PBSwiss ones. I still like the PB Swiss best, but I’ve had them longer and just might be more used to them.This is pretty much what I found with their hex keys. Superb for using on a deformed screw, but for everyday use, PB Swiss are a better choice.
The Nepros bits are looking very tempting…
Very soft. Tend to deform and twist quite easily. While the business end is replaceable, you gotta track down a Snapon truck and on top of that they don’t stay in the sockets that they are pressfit into. I love the rest of my Snapon sockets, but their hex / torx stuff *****. Im pretty convinced after owning a bunch of both, everything Nepros makes is superior to Snapon.Why not a fan?
I just made an Amazon Japan order, trying to get all the "little" things to add on as they don't really charge more shipping. I remembered I needed an open 23mm wrench for a camshaft but got by with a cresent wrench. Put a cheap one in my cart (if I have it I will never need it again..) and noticed an odd description after checkout. See if you can spot the translation.
So I guess you can expect some solid engagement.and noticed an odd description after checkout. See if you can spot the translation.
Oh, and I love the magnetic bottom of the Ko-ken Z-eal socket holder. It's just beautiful, solid and also has a foam layer on the bottom. Not as time saving as a Hansen-type holder, but I'm not working flat-rate out of my garage.
I agree with you 100%. Ordered some Koken, KTC, and PB Swiss tools from them. Fast shipping (free with $100 order) Packaging was top notch!Just wanted to say how satisfied I am with my shopping experience with drpd.cc. Ordered a Ko-ken 3/8" deep socket set along with some universal joints, and DRPD packed them as if they came straight from Japan. Definitely recommend them.![]()
This goes for Germany, or anything out of Europe too.Saw this on Reddit today. I'm not exactly sure how best to take advantage of it, but it seems like it's a good time for those of us stateside to buy some Japanese tools.
kokenusa.com
Yes. It was supposed to be available in 2022. Only 3 months left and it will be 2023.....anyone know if Ko-ken's planning to make their 1/4" line in 72-tooth versions as well?
Pretty sure those are the same as the Ares rails. I bought one for testing before SK and Koken started selling them and they looked identical last I checked. Not sure who the actual OEM is but because other companies use them, you can get them in different colors.yeah, those Ko-ken Zeal socket rail magnetic are really strong !
A 13.5mm square Koken socket, 1/2" drive, from KokenUSA. Cost me a grand total of $12.72
1/2 Sq. Dr. Bit Socket 13.5mm Square Length 32mm For Drain Plug -
Input Drive Size: 1/2" Drive Shape: Square Length: 32mm Type: Bit Socket for Drain Plug Output Size: 13.5mm Output Shape: Square Product Dimension - Ko-ken USAkokenusa.com
Thanks to the strong dollar reminder I just "had to" do this.
I keep logging on to Amazon.jp to see what I can buy that I "have to have."
But I keep struggling for some reason.
I was going to buy the KTC 45* offset DBE 6-piece set. But I think I'm just going to end up going with Tekton. Tekton is completely fine enough for my DIY needs and their sets are more complete a lower price or much larger for a moderately more expensive price.
Have you looked at Stahlwille? They've got some nice offset DBE's for reasonable money.
I've also seemingly run out of stuff I "have to have" from the Amazon.jp. That's probably a good thing honestly.
