Astro_Pneumatic_Tools
The GJ deal has ended, below is info on the product. Thanks GJ!
You've asked for them, you've waited, it took awhile but we're finally making them under Astro. For just under half the cost found on these before now.
Though as far as drill bits go, obviously these do take quite a few extra manufacturing steps compared to what you find in a Hardware Store
(if the site says shipping October or whatever, that's not the case. They should be getting stock from several of their tool warehouse customers this coming week)
TurboStep drill bits, patented drill bits that are traditional spiral fluted but the tips are all each small step-drill designs that seriously change the game when starting holes, drilling large sizes without pilot holes, drilling quickly through sheet metal and leaving a clean circle, and just drilling through hardened and imperfect surfaces much faster and with less effort compared to traditional and split-point drill bits.
Basically spreads the job of making a hole over several individual spirally located cutting edges making each have to work less hard and also mitigating a lot of the heat involved.
If you havent had an opportunity to use these type of drill bits yet we highly recommend talking to someone who has.
- Reduced shanks over 3/8" so you can use in 3/8" drills on all sizes
- 3 flats on the shanks to prevent spinning
- Onyx oxide coating to prevent chip adhesion
- The same top shelf high-speed steel we normally make these in
- These are the real deal with several US patents
Astro Tools TS29 ONYX 29pc TurboStep HSS Reduced Shank Mechanics Length 1/16" - 1/2" Drill Bit Set - - Amazon.com
amzn.to
Astro Tools TS21 ONYX 21pc TurboStep HSS Mechanics Length 1/16" - 3/8" Drill Bit Set - - Amazon.com
amzn.to
