The Wizard
- Joined
- Apr 9, 2010
- Messages
- 88
Hello,
I'm in the middle of installing the HD-9 four post lift. Up to now, the instructions have been pretty poor in some areas but I'll talk about that later once the lift is done. I'd like to use this thread to gain help throughout the install, and to assist future lift buyers.
Right now, I'm stuck on Step 7 (Cable/Sheave installation)
The instructions read, "In order to install the cables it is necessary to first extend the Hydraulic cylinder. Remove both Cylinder port plugs then use an air gun or come-along to extend the cylinder."
I removed both ports as instructed, then tried to use my air gun to get the cylinder to extend, no luck. And I don't have a come-along.
Anyone else have this problem? What did you do to get the cylinder to extend?
Thanks in advance.
James
Thanks in advance.
James
!! With a little help from your highly experienced GJ friends, you'll get through it!! Most of us set our up without help and with the same instructions!!!
