Sliding Gate Valve - Pool center drain
D45
NW INDIANA
What would be the cause for a gate valve to stop working?
Tried to winterize my pools center drain and the gate valve handle would close but would not stop the flow of water
D
D45
NW INDIANA
I'm going to cut off the glued in gate valve and install a glued on threaded fitting
Then order a threaded gate valve in case it fails again, I can just thread on a replacement
kaymccampbell
Upstate New York
Absolutely use a ball valve. The internals of Hayward valves are easily serviceable and replaceable. I disassemble, clean and grease all the valves in the pool pump manifolds every year.
D
D45
NW INDIANA
For a 1-1/2" pvc pipe
Would a threaded ball valve be air tight? When I winterize my center drain I use compressed air to blow out the water in the line then shut the gate valve and cap the line
mike93lx
Richmond, VA
If it isn't water tight, it isn't air tight. The pressure should be low in both situations (20psi ish).
rayra
Escaped from Los Angeles
2" pvc ball valves are $15-30. Not cheap, but certainly not 'pricey'.
Jandy's are pricey. Great if you are tying them in with some sort of automation, solar heater, etc.
D
D45
NW INDIANA
A threaded valve with a threaded fitting is what I'll be looking to install
I just want it to last, the gate valve lasted under 4 years. Plus it's glued in so replacing it with a threaded valve will be a good idea IMHO
mike93lx
Richmond, VA
Do you mean using unions, right? You'll have to use them to make it removable. Just a threaded valve will still require cutting
I just had a pool built and outside of the equipment connections, there isn't a union anywhere. Valves are all glued in. If one fails and somehow cant be rebuilt, they just cut it out and install a new one.
D
D45
NW INDIANA
No not a union, but I could use them.......
I was thinking about a "slip on to threaded" fitting .......that would be glued on to the main line coming up out of the ground
It would be threaded on then and the main control valve would be threaded on to the center drain valve
mike93lx
Richmond, VA
I guess I'm not picturing it. Just wanted to make sure you aren't gluing yourself into a corner despite using threaded fittings
mike93lx
Richmond, VA
"2" pvc ball valves are $15-30. Not cheap, but certainly not 'pricey'."
He already tried a crappy valve made from PVC, why send him down the same rabbit hole.
Go on Ebay, either get a large full flow metal ball valve or a standard brass or SS full flow gate valve.
Does anyone use those on pools? Seems beyond unnecessary.
kbuhagiar
Escondido, CA
I don't think so. I'm a swimming pool maintenance rookie (new owner of a 22-year-old pool) but I am learning fast. I think it has something to do with the pool chemicals, they may cause the metal (brass/copper) to leach out over time and stain pool surfaces.
I haven't yet seen a single pool with anything other than PVC fittings.
But, like I said, I'm still a rookie and I could be wrong.
mike93lx
Richmond, VA
Rookie owner as well (2 months on a new build) but I grew up with a pool. Not a piece of metal in the plumbing of either system.
CSRPenFab
Meridian Idaho
The pool at my prior house had Pentair automated ball valves for filter/pump. On the drain side, they added a simple 2" Hayward ball valve since my spa was elevated from the main pool, and it gave you a way to isolate the spa water and prevent drainage when working on the plumbing. Very simple, very reliable, and I never had an issue in 5 years of ownership. Cheap at under $8 too!
D
D45
NW INDIANA
I have a vertical section of 1-1/2" pvc pipe coming up out of the ground
I was going to cut off the failed gate valve thats currently glued to the vertical section of pipe
I would like to then glue on one of these two fittings, depending on the type of valve I go with
Then, when and if, the new valve were to fail I could just thread on a new valve
D
D45
NW INDIANA
Current setup with gate valve
mike93lx
Richmond, VA
That will work. No unions needed when you can free up one end easily
  • Like
Reactions: D45
BombShelter
State of Hockey
I wouldn't use a metal valve with chemicals and outdoors, one frost and they split in 1/2, the chemicals will eat them alive, that's probably what happened to you gate valve, those cheap ones never last long, I don't think I've ever seen one used like that, it looks like a fail-safe valve.
Your looking for a "True-Union" ball valve, they come with two ends, either threaded or socket. These ends are threaded on the main body so the body is like having a union. The good ones, George Fisher, Spears, Hayward are all servicable down the road or easy to replace. I wouldn't use those cheapo valves pictured above, you can't repair them and they quit working after a few years. Hayward will probably be your best value, GF and Spears go into a lot of industrial applications and can be spendy.
  • Like
Reactions: D45
BombShelter
State of Hockey
Here's a true union Hayward Valve from Amazon, the ends can be socket or threads, both come with the valve. The cheap Haywards are mostly for leaving on all the time except for an emergency. It looks like the gate valve was relaxing pressure while the diverter valve above was shut off. You almost have to make a loop to make the system fool-proof, if the gate valve fails, you can't stop the water flow to fix it if it's an above ground pool.
D
D45
NW INDIANA
Seems with a union fitting there are more seams and possible opportunities to leak?
yeldogt
OK .... help me out here . Why are you taking all of the piping apart around the Hayward control valve.... ? Was the gate valve used to reduce the flow from the main drain. Also .... you can't really blow out the line to the lower drain in the same way as others -- tricky spot.
With pool piping you have to be strategic. I hard pipe (glue) in Jandy valves from the supply lines and then use the heavy flex PVC to the pump/s. I glue the Jandy side and you need to use a male to the pumps. I glue the male to the flex. I also use the flex from the pump.
Jandy valves last a long time -- you can rebuild them. When things finally fail in 20 years you just cut the whole thing out and start over. Unions on the supply are a pain as they can leak and draw in air .... same with the Hayward valves. There really is no reason to take them apart.
Typically if you need to replace a pump housing (rare) ... you cut the flex and glue it back with a coupling. You can also use a male and female on lines coming out of the ground (or anyplace else) -- this way if you need to fix something you just cut above and unscrew the joint. I find that in most pools you have pipe in the ground -- hard glue it in place and when you need to fix something you just place the hard coupling at or below ground level.
I do use a union at my Polaris pump ..... in my case it is hard piped and the two unions allow me to remove it. For years I just had it hard piped (I just cover them for the winter). When it died I glued in the unions and never use them .... if I do it again to this pool I will just hard pipe them again. I only use the threaded in spots where fixing would be difficult or when the equipment had to have a threaded connection.
Also -- the typical white and red valves w/ white plastic bodies have a limited life. Some are better than others ... the major makers are what you want. The more sun the equipment gets the more you have to worry about them. The handles snap and the balls get tight. The solution is Schedule 40 valves -- they cost a lot more.
The white Hayward valves yellow and get brittle --- very annoying products. Jandy are what I use .... I have never replaced one of the bodies ..... just install a new head. Normally it's just grease or new gasket
D
D45
NW INDIANA
I drain the water below the skimmer and remove all the pool hoses and equipment every fall to store them inside the shed
I then blow out the center drain to help protect it from freezing
The gate valve is merely to shut off water to and from the center drain, for maintenance and for winterizing
D
D45
NW INDIANA
I am going to look online and try to get a fitting and ball valve ordered today...........sounds like Hayward or Jandy is the route to go.
I am looking for a slip on (glued) Sch 40 fitting that will go over a 1-1/2" pvc pipe and this fitting will also have a threaded male 1-1/2" portion on the other end (for the valve to thread onto). Is there a special word for this type of fitting?
Will this slip over 1-1/2" pipe?
mike93lx
Richmond, VA
MPT x Slip sounds like what you are talking about, but if you are getting a high quality, rebuildable valve, skip the threaded connection and just glue it
  • Like
Reactions: D45
D
D45
NW INDIANA
I found the slip on fitting, now I need to figure out how to stop the flow of water when I cut the pipe to glue this on
jkuro
A lot of times debris gets stuck in the gate valve and keeps them from closing. Try this, open and close the valve numerous times, a lot. Sometimes this open and closing will crush and dislodge any junk that was stuck. It's worth the try before rebuilding.
D
D45
NW INDIANA
I tried opening and closing it many many times
Once I cut it out I'll tylry to inspect it
I like having the threaded fitting for attaching the valve, rather than a permanent glue on valve
