I agree, use a ball valve. And unless you have a union, using a slip-fit to threaded fitting on each side, you need to cut the pipe somewhere to remove the valve anyway.Why not just run a ball valve?
If it isn't water tight, it isn't air tight. The pressure should be low in both situations (20psi ish).For a 1-1/2" pvc pipe
Would a threaded ball valve be air tight? When I winterize my center drain I use compressed air to blow out the water in the line then shut the gate valve and cap the line
Do you mean using unions, right? You'll have to use them to make it removable. Just a threaded valve will still require cuttingA threaded valve with a threaded fitting is what I'll be looking to install
I just want it to last, the gate valve lasted under 4 years. Plus it's glued in so replacing it with a threaded valve will be a good idea IMHO
I guess I'm not picturing it. Just wanted to make sure you aren't gluing yourself into a corner despite using threaded fittingsNo not a union, but I could use them.......
I was thinking about a "slip on to threaded" fitting .......that would be glued on to the main line coming up out of the ground
It would be threaded on then and the main control valve would be threaded on to the center drain valve
Does anyone use those on pools? Seems beyond unnecessary."2" pvc ball valves are $15-30. Not cheap, but certainly not 'pricey'."
He already tried a crappy valve made from PVC, why send him down the same rabbit hole.
Go on Ebay, either get a large full flow metal ball valve or a standard brass or SS full flow gate valve.
Rookie owner as well (2 months on a new build) but I grew up with a pool. Not a piece of metal in the plumbing of either system.I don't think so. I'm a swimming pool maintenance rookie (new owner of a 22-year-old pool) but I am learning fast. I think it has something to do with the pool chemicals, they may cause the metal (brass/copper) to leach out over time and stain pool surfaces.
I haven't yet seen a single pool with anything other than PVC fittings.
But, like I said, I'm still a rookie and I could be wrong.
This would allow you to easily remove it and isn't particularly expensive.I would need and use a valve with 1-1/2" openings/threads
That will work. No unions needed when you can free up one end easilyI have a vertical section of 1-1/2" pvc pipe coming up out of the ground
I was going to cut off the failed gate valve thats currently glued to the vertical section of pipe
I would like to then glue on one of these two fittings, depending on the type of valve I go with
Then, when and if, the new valve were to fail I could just thread on a new valve
$7.43 on the pic I posted for a 1 1/2”.I would need and use a valve with 1-1/2" openings/threads
Yep.$60 for a 1-1/2" plug tool.........ouch
