vrinner
OK...so it's been hot and pretty much can't really do much in the shop. Steel building, fully insulated and no ventilation or A/C yet. I figure an inexpensive start would be to put in a gable vent at one end up high and then an intake vent low on the other side. Run it at night to keep the interior cool as well as occasionally to control humidity. From reading around I think that will be a good thing to get started with but a couple of questions on placement.
I am looking at getting a vent like this from HD and mounting it up fairly high on the west side of the building.
Is that all I need...as in cut the hole, add the proper trim for water proofing/run off and then mount the fan/louvers into the opening or do I need any other sort of box around it?
Then for the intake I'm thinking of just cutting a hole in the man door and putting it on there. That side of the building does get some afternoon sun but figure I probably wont be running the fan during the heat of the day. The other thought was to cut a hole in the building on the north east side as that is always in the shade.
iLIVING 3368 CFM Silver Electric Powered Gable Mount Shutter Fan/Vent ILG8SF20VC - The Home Depot
The iLIVING smart remote shutter exhaust fans are equipped with a thermostat, humidistat, variable speed and timer. These fans can be activated with a remote control up to 1,000 ft. range. The iLIVING
www.homedepot.com
