Williams Taiwan Hex/Torx Bit Sockets?
65k10
somewhere
I'm looking for a set of torx and hex bit sockets to keep in my pickup tool set. The Williams 50681 set has the sizes I want and the price is in the realm of what I'm willing to pay. These will likely be seeing limited use, but I want something that will work when needed. Will these fit that application? I also considered VIM since I have used those and they worked, but their bit socket sets cover a larger range of sizes than I need in this case.
boom_bap
Idaho
So far my favorite bit sockets have been the Capri sockets, over the VIM stubbies I have.
Metric hexes: ‎CP30002ADV
Torx set: CP30004
The metric hex sockets have held up for me for DIY use. I use them on bikes all the time and cars where applicable.
I had a drain plug that was on so damn tight I thought for sure it would strip the 6mm socket or at least the bolt. after I broke it loose I thought I'd broken my ratchet hah and the bit is still in great shape.
The torx sockets I just picked up the cp 30004, haven't tried them yet, but doing brakes soon and it required a t55 and rather than just get 1 socket for 8 bucks I just bought the set for 35. Total for both sets would be $55 bucks.
Keep in mind that the Williams set doesn't have T55. I have a set of torx that went fro T10-T50 and I need a T55, so I had to buy either 1 socket or set. Thats why I just picked up yet another set. Something to keep in mind.
2ndGearRubber
Pittsburgh
I have both williams Taiwan and bluepoint. They are my go-to 1/4 drive hex on my cart. The bluepoint are security torx, and thus a bit weaker than a full bodied non-security bit. Both have done well for me.
VIM stubbies are sort of a different product than regular bit sockets. If choosing bit sockets, I highly recommend S2 steel bits. Long lasting and strong. S2 bits aren't crazy money, the capri set above is S2. It's just a know good quantity and easy to filter by. When selecting the bits you wish to carry with you, consider what all you're really going to get into on a mobile repair.
BlakeTheCarGuy
Roanoke Virginia
My preference is Capri I use them professionally. Great tools well made in Taiwan. I use them on impacts no issues. Order from their website and get points for future purchases. I don’t have experience with Williams ones but they usually have good stuff. The Capri has many varieties of sets so I’m sure you’ll find one right for you and the price might be better too but I’m not sure.
AJHD
I struggled with buying hex and torx sockets. Honestly I still want to buy Snap On, but I've not be able to bring myself to do so, yet.
Anyway, I also settled on Capri. At least for now. They seem good quality for the price so far. I was also able to get just about every size available, except a few of the larger 1/2" versions, for both metric and SAE (hex).
I was also looking at Williams, but they are limited on sizes. As are most other sets/brands. The BluePoint 87-piece set is a good option too, but I'm not paying a premium for off-shore Taiwan tools.
getbentMUSTARD
Lusby, MD
I don't yet have their Torx bits but I have all VIM hex bits and can't recommend them enough. No twisting or slipping and the bits hardly show any use.
If I didn't have the VIM bits and needed it all I too would likely go the Capri route. Non-stepped hex bits in the large kit and a great price.
2ndGearRubber
Pittsburgh
VIM is a top notch product.
However, the stubby for factor makes it a slightly different tool. For instance will you be keeping a 1" or 1/2" extension if you need to space that stubby out? More often than not, the stubby is actually preferable. But just keep in mind the extension factor.
65k10
somewhere
Thanks for the replies and other options. I'll give Capri a look. I had also considered insert bits for the smaller sizes and using regular hex bits for larger sizes since it gives me more flexibility and saves space. I'm trying to decide if I want to take the time and the extra shipping to put together a bit set from several sources vs. ordering a single set that has most of what I need.
The tools in my vehicle isn't so much for on the road repairs for the vehicle itself. I'm on a farm, so it's helpful to have tools in most of the vehicles so things like basic adjustments and teardowns/repairs can be done in the field without having to run home for the basics.
KnurledNut
n/a
@65k10
Some things about that Williams set just dont seem logical to me.
Like they include a 1/8” and 4mm hex, a PH1 and a 3/16 slotted in 3/8 drive, but the T25 T27 T30 are only 1/4 drive. :headscrat
getbentMUSTARD
Lusby, MD
They make regular versions as well though. Currently eyeing their master torx set PN# TMS34PF
toddmorr
Potomac, Maryland
was doing a differential service on a Toyota 2 weeks ago and needed a very short 10mm hex, ended up using an L key and pipe, not cool. Koken to the rescue.
VIM tools 1/2 10mm on far left
MAC 3/8 10mm
Koken 3/8 10mm
Koken 1/4 10mm
AJHD
Interesting comparisons. Those Koken sockets look nice.
Stormin1
How are the regular mac torx / hex sockets ( not the RBRT )? Are they a step above VIM or relatively the same?
AJHD
Not really. Might as well buy VIM or Capri and save some $$.
Agreed. Anything MAC is going to be rebrand anyway, so unless you have a MAC dealer you see every week it's not worth the extra cost.
