Compressor mounts for free!
jayoldschool
Canada
Here are a few shots of the mounts I fabbed up for my new compressor. Three hockey pucks, drilled for bolts, countersunk on the bottom for the heads and a washer, topped with a large washer, a locking washer, and a nut. Scrounged up everything for a total cost of zero :D
J
jayoldschool
Canada
Forstner bit. Drilled the center hole first so everything was aligned.
collingwood
lilredex
Toronto
OK, so what's the rest of the story? How are you actually going to use them?
More pic? Please.
gatchel
West of King of Prussia, PA
That will make it easy to move when you want to. Just open the door for a few days, hose down the floor and slide it on the soon to be ice in that wonderfully cold climate you live in.
lilredex
Toronto
You just bolt them to the feet of the compressor
And they sit in a recess of some type to keep everything in place? When I first saw them I was thinking they were just vibration dampers on a "through" bolt down into the floor or other, and what good would that really be. If I did that with mine it would be on the floor in a minute. The front is bolted securely to the bracket on this one, and it does vibrate some.
trbomax
starvation lake,mi.
Somebody please enlighten me,because I dont see the point in trying to insulate a compressor from a concrete floor.Simply bolting thru rubber doesnt reduce harmonics,you would need an isolation sleeve in the center of it,or a rubber puck under and on top of the mounting foot.Would seem to me, it might shake worse if it could move.
rcozzo
Delaware,OH
I countersunk my bolts the same way using a spade bit. The best part is the smell of burning rubber while drilling them.
Gary S
Bismarck, ND
I just left my compressor on the pallet it was shipped on. The pallet does a nice job of isolating it too. Hockey pucks would cost me money. We don't do much hockey here. We do a lot of rodeo, and saddles don't make good compressor mounts.:shocking::shocking:
89MustangGX
Stanwood, WA
Ok, the idea of hockey pucks sounded kind of cheesy to me at first, but after seeing it done, it looks like a nice cheaper alternative to industrial feet that I was going to purchase.
I'm going to look into this now -- thanks.
Adam
tbob
KCMO
I just used old worn out hard rubber 3" caster wheels my business was going to throw out. Hole already cut with sleeve. Cut sleeve a little shorter & Bolted to floor, works great.
Terry
logical
Northern fringe of the Motor City Suburbs
I've seen a lot of people use them on the forum but I always thought they were a little on the ard side to actually reduce the vibration transferred into the floor. I found some actual purpose built machine isolators cheap on Ebay and they are pretty soft and about 1.5 times the height of a puck. Picture a 2x size marshmellow. They are soft enough that I can jiggle the compressor an inch or so at the top (mine is a 60 gal. horizontal so that's quite a bit) easily but it has never walked and doesn't seem at all unstable.
All I have handy is this wide shot of the whole compressor.
Notch1988
Fort Saskatchewan, AB, Canada
LOL... being from Canada I used hockey pucks too. I used lag screws and two pucks per leg in the back. For the front I drilled two anchor bolts into my floor and slid hockey pucks over the anchor bolts and then bolted the compressor down.
Dan in Pasadena
Pasadena, CA
...oh, I'll just run over to my BOX of hockey pucks. Oh, thats right I live in Southern California. What's a hockey puck?:bounce:
Seriously, it DOES look good. BUt it wouldn't be free here. I honestly doubt any of my local sporting goods stores stock hockey pucks.
Demian
Cape Coral, FL
I think you'd be surprised how much hockey there actually is in SoCal.
On topic, I like the pucks and despite being in Southwest FL I have an abudant supply:)
Falcon67
Merkel, TX
Makes you wonder what those poor folks in the southern states do without hockey pucks.
They sell 'em here too, Mr. Smarty Pants. ;)
Actually, the thing I did for my compressor was to cut three 3" squares from the horse pad that the washing machine sits on. No bolts, nothing. Just slid the pads under the feet. I have a catch loop to hold the compressor should it tip, but it hasn't moved not 1mm at all in over a year of use.
http://www.tractorsupply.com/equine...t-rubber-horse-stall-mat-4-ft-x-6-ft--2219003
msmith
I have an 80 gallon vertical tank Ingersoll Rand compressor. I used solid rubber pads that are about 3/8-inch thick with a u-shaped channel to pass the bolt through. I used 1/2-inch anchors into the concrete floor with the rubber pads between the feet and the concrete. It purrs like a kitten and is solid as a rock.
FlameOut
Pittsburgh, Pennsylvania
I ended up using left over body bushings. I had a bunch left over from my Chevelle restoration. And they already had the hole in them. I was about to go the hockey puck route when I remembered I had this stuff left over
TooTall
So. Cal.
I'm in So. Cal. by the beach. I have a bag of about 2 dozen hockey pucks out in the garage. They make great jack pads. There's lots of hockey in So. Cal., even in Pasadena;
http://www.pasadenahockey.net/
One of my sons former team mates was just drafted by the Penguins in the first round of the NHL draft.
Kurt O.
Jim Stabe
San Diego, Ca
San Diego isn't the hockey capital of the western hemisphere either but I bought a dozen online for $1 apiece. I have mounted my 80 gal air compressor, my 3,000 lb milling machine and 1 1/2 hp buffer with them. They work great and the buffer doesn't scoot across the floor when I use it.
dkroth
Rochester, New York
lol, I live in Canada. Hockey pucks are more common than pennies in your change.
I live in the United States. Pennies are very uncommon in pocket change. I have never carried, nor have I ever met anyone who carries, pennies in their pockets here in the States.
Cents, on the other hand, are quite common.
:):bounce::):bounce::)
C'mon. It's Friday!
84scrambler
Livermore Ca.
I ended up using some scrap delrin that my buddy had at his work. The center was counter-bored and I was able to put it together for next to nothing. I attached a picture but unfortunately its not a close up but you can make it out in the bottom left hand corner to get an idea.
PCO6
Newmarket, Ontario
C'mon. It's Friday!
I didn't know that. It's fairly common around here ... or atleast it is when I am in line behind a woman that will search for what seems like a minute for 4 cents rather give a cashier a nickle and risk getting a penny back.
When a cashier asks me ... "Do you have the 2 cents?" ... I often say ... "I have no cents at all". Half of them don't get the joke and just carry on. A quarter of them do and you get a laugh or a smile. The rest act ticked off, which is often why I say it in the first place.
boosteddsm92
MD
Thanks for the idea! Doesn't get any easier, and you have a large mat leftover for anti-fatigue or whatever you want to use it for! Just got my compressor wired up today, loving it. Next is some nice plumbing for it...
