Maxcustody
Thank you! This is great information and very similar to my setup. I will have it tomorrow or Friday. I will leave it bare steel! I am also adding my vise and will look at mounting it like you haveWhen we built my main workbench, we used a plain 10ga steel top, with a bent over front edge, and a bent up rear back edge. The front lip is 1", and the back edge is 4". We built it on a wood 4X4 and 2X6 heavy duty framework, carriage bolted together. The top is attached by pieces of angle iron welded to the bottom side of the top, and carriage bolted through the frame.
On the corner where the vise was going to be installed, we welded a section of 1/2" plate to the bottom side of the top, and cut the 2X6s for clearance. The vise bolts though the top and the reinforcement plate, and that works out well.
Nothing at all was done to the top surface; we just left the mill scale on it. I've had no issues with it rusting in normal use. When needed, I spray it with BraKleen and wipe it off. Over the years the mill scale has worn off in some areas, but most of it is still there.
The bench has served me well for 20+ years in my truck shop, and 11 more years in my retirement shop so far. Even though 10ga is kinda thin for a heavy duty bench top, if it has a good frame underneath it can work quite well. Many projects have been beaten back into shape on it, as well as many welding jobs done on it. It was not designed as a welding bench though. It was envisioned as a workbench you can weld on. It has a few lowish spots in the top after 32 years of hard use, but that is to be expected I guess.
These are pretty much the only photos I have of it, with Nothing on it. They are from back when I was setting up my retirement shop, and I had let it sit outside for a week or two. That is why the top has a rusty tinge to it. When it is kept in a shop, it never looks like that.
