apeters62
Just had a new metal building installed and it came with Trac-Rite roll up doors that have a slide lock on the outside. They make a cylinder lock that goes into the slide for a cleaner look. The problem I see is that to open the door, you pull the whole cylinder lock out so then you have to put it somewhere. I could see it being easily misplaced. The other option is your basic padlock which doesn't look as nice and you still have to put it somewhere while the door is open. Also, not sure if one is more secure than the other. Obviously you could get into both. Below is the link for the Spaceguard cylinder locks that go with the door. Just looking for thoughts and experiences. I'll probably add additional slide to the inside bottom of the door as well. Thanks
www.tracrite.com
Spaceguard Cylinder Lock Keyed Alike - Trac Rite
Cylinder locks, all keyed alike. For uniquely locks order part #502705 PDF Datasheet
