New air compressor issues
daddycreswell
Middle Tennessee
I finally broke down and bought myself a 60 AC, I have been using a 15 gallon craftsman for 20 plus years. I am a hobbyist powdercoater and sandblaster, but I was using my SB yesterday and noticed that I had a bunch of water mixing in, so I hit the tank drain and orange goop come flying out. When I setup my AC I grab a air filter from HF thinking that would cut it, well clearly it didn't. So my questions is will the Desiccant dryer/filter from HF be enough to fix my issue or do I need to do some of the things I've seen on YT with radiators etc? Thanks
Walkers
Cave Creek Az
Need to drain your tank of fluid (just open the bottom drain valve for a couple seconds) every day that you use it, or get an automatic drain valve. 50’ of pipe from the compressor to the use points is an excellent method to get the air cool enough for the vapor to become water, which you can then remove with a common water filter. Eve if you use say 3/4” pipe and go up the wall from the compressor and then along the wall at the ceiling for two or three walls and put in a few drops along the way it should work just fine.
Imatk
If your shop is hot/humid that has a lot to do with condensation. But even with a cool shop you'll get water. I have about 20 or so feet of copper pipe going up a wall into a filter and dessicant and it doesn't take long for the dessicant to get spent.
I also have a radiator/aftercooler and water trap coming that the air goes through before it even reaches the tank so it cools the air quite a bit with that.
I'm about to add a Motorguard filter before my other filters, just haven't gotten around to it.
But basically I still trap water in my outlet copper line (I have two traps before that one one before the filters and one after).
I don't get enough that it's an issue at this point, but I think a lot of it has to do with outside temps. I see you're in TN so if it's hot and humid there like it is here in the summer you'll have more issues then than you will in the winter/fall
GeoBruin
There is lots and lots of information on this forum about this topic. Once you get a couple of the terms from responses here, I recommend using the search function and pulling up some of the threads that go into details about some of the various means by which folks have dried out their compressed air. That said, in short:
- Drain your compressor daily. This will not help much/at all with keeping your air dry, but it will prolong the life of your compressor.
- water traps and dessicant filters do work, but to maximize their efficacy, you need to cool the air as much as possible before it reaches the drier/filter. Simply put, this is because cool air can't keep as much moisture in suspension (all else being equal) as warmer air so the moisture in the air condenses into liquid water, which the traps are more effective at capturing. There are many ways to do this. This list is not complete, but it is roughly organized from least to most effective (and also from least to most expensive):
- Running the air from the compressor tank outlet through a length of pipe. The idea is that the ambient air temperature (and thus the temperature of the pipes) will be cooler than the air coming out of the compressor so they will act as a heat sink to remove heat from the air.
Pipe materials that have higher thermal conductivity and/or higher thermal mass (or the best combination of both) will be more effective, but will also be more expensive. Copper is great, but is expensive, aluminum is good and there are several commercially available aluminum pipe systems made for this purpose (rapidair's fastpipe is the most common) steel, such as black iron gas pipe is popular and all the pipe and fittings are available at most hardware stores.
The length of you pipe system is important. If you have a big shop and you have 50 foot runs along 3 or 4 walls as part of your distribution system, that will probably be plenty. But if you have a small shop, or if your point of use is near your compressor, you may need to introduce extra length by running "laps" with your pipe before your trap. That said, buying extra pipe just to cool the air (rather than it doublong as your distribution system) can add cost quickly and you may be better served by looking at one of the other options.
One last point with this approach is that you need to add places to drain the water throughout, and ideally, you are constructing your pipe system in a way that the water is encouraged to drain toward a low point. It's easier to capture and drain water from the pipe system than to pump it all into your trap/filter. You will quickly saturate your filter otherwise and it won't be as effective.
- Another option is to cool the air using a radiator as you mentioned in your post. This form of aftercooler is kind of passive in that you are typically using air flow from the flywheel to pull air through the radiator, so you're not powering it separately. Ideally, you plumb the radiator in between the outlet on the pump and the tank so the air is already cool as it enters the tank and the water can condense into tank rather than downstream of the tank where it will need to be trapped and drained out again anyway.
One additional measure can be to add a water trap after the radiator but before the tank so less water is collected in the tank. This is a great option requiring minimal space, no additional power, and minimal investment (these radiators are fairly affordable in the context of an air system) but do require so plumbing/mounting and you will still never be able to cool the air down below the ambient temperature.
- Another options is a refrigerated air drier. This is exactly what it sounds like. The air is pumped through a separate refrigerated unit requiring its own electricity. The advantage is that you can cool the air down well below ambient temperature allowing even more moisture to condense out. The disadvantage is that these driers can be expensive and consume additional power. They are also typically larger and heavier than a passive radiator so you will need more space to mount it on or near your compressor. They will also require a bit of plumbing to install.
Only you can decide how dry your air needs to be based on your needs, but sandblasting does benefit from drier air. Also, as other have mentioned, the temperature and humidity in your shop will determine your starting place in terms of how much moisture is in your air to begin with.
Good luck!
stevied916
Northern CA
I added an aftercooler on mine with a water trap and it seems to work really well. You need the hot air out of the pump to cool so the water will condense which is then removed by a water trap. I used a transmission cooler for the aftercooler and it drops the temp of the air from 182 - 70 degrees. Pump->cooler->water trap->tank
Without cooling the air, nothing will work well enough to remove the water.
Pic of mine below. Ideally, you don't want the bend from the cold side of the cooler to the water trap as I have on mine but it seems to still work extremely well.
engineer2
Chicago burbs
An aftercooler is a good start and if well-designed like stevied916's above, can remove half the water in the compressed air. Except for those very humid days, this and some drip legs will be enough.
If you want to get more out, search Craigslist for a used refrigerated air dryer. Just avoid old R12 units due to refrigerant hassles.
GeoBruin
Pic of my similar setup.
