rlitman
I'm too cheap to buy the special Snap On socket made for those, so I use an Astro Nano socket with a 6" wobble impact extension on my stubby impact driver. I use the impact to break the bolt loose, and then take it off with either a wrench or my fingers, because the Nano socket gets trapped by the strut nut. The Snap On shallow socket gets around that issue, but costs around $60.Also the stupid caliber bracket bolts on the outback that are obstructed by the strut. You're not putting an impact on them and they're loctited in.
And I pray it is loctited in, and I always put blue on it before I re-install. If it isn't loctited, it rusts, and when it corrodes, you're fighting the threads all the way out. When it is loctited, you just need to break the bond loose, and out it comes.
