Above 1200 Sq/FT OldCarGuy’s New Toy Shop
O
OldCarGuy
Indeed it was a huge loss for me, both monetarily and emotional. The fire occurred December 20, 2020. Both the local Fire Marshall and my insurance company wouldn't give me a go ahead with any repairs, let alone entering the premise. Until all the investigating was finished, because of the expected legal ramifications to the computer company. Unknown to me, the particular model computer has a major issue of causing fires.
After three months of stalling me, I started in on the fire restoration on my own. Most told me I wasn't capable at my age to the task at hand. My thoughts were I built my garage complex on my own twenty years ago. Just because I'm approaching eighty years old, that's not going to stop me now! Ordered a huge dumpster,, actually four of them. Removed all the burned remains, and took out all the machines and stored them in my other garages or offsite. Then removed all the machinery wiring that was surface mounted in steel conduit. The wires were all melted as one from the high heat. Lastly I removed all the drywall and fiberglass insulation knowing the smoke smell would linger for years.
I took on the task without any outside contracting! And only the help of a single family member. Working seven days a week 10 to 14 hours a day.. Besides some minor details, I finished the massive project. The results are fantastic! Except for my 1914 Cadillac, all my other cars were safe from the fire. Note to BuickFarmer my 1910 Buick is fine.. Along with my six other Buicks and other mark cars... Here is a taste of the restoration today... I'll be posting more about my joinery soon.
Below is a shot looking down a row of my equipment. You'll notice on the far wall below my license plate collection is a neon sign, “Grandpa's Toy Shop”. Maybe I should start a new thread naming it as such..
larry4406
Northern Virginia
Old Car Guy - So glad you are back.
I feel very sad for your loss but also impressed with your get up and go and kick *** attitude at near 80 to just get in there and do it!
zmotorsports
Northern Utah
Old Car Guy, that was a hard read but I am glad you opted to rebuild.
Your shop and garages were part of my wanting to join this forum way back in 2009. I had been perusing the interwebs admiring shop builds and yours was one of the ones that popped up on this site. I have admired it ever since and have missed your postings.
Sorry that this happened but glad you rebuilt and I hope we will see more of you on the forum with your projects and cars.
southalabama
Brewton AL
Looking good. I have many of your shop pics saved in my idea files. Glad your back.
O
OldCarGuy
OldCarGuy's New Toy Shop rebuild that's even better!
After removing all the drywall, insulation and surface wiring that was in steel conduit. New insulation is installed. Besides new insulation in the walls, the ceiling's 10” was replaced too.
I picked up new 4' by 12' fire rated 5/8” drywall using my tilt bed trailer. They wanted $75.00 to drop it off and couldn't guarantee they'd be able to get it through my 8' by 18' door. Here's what 10,000 pounds of drywalls looks like..
Then installing the 110 pound sheets in ceiling first. My drywall lift and power scissors truck came in handy...
Being on my trailer I could easily slide the heavy sheets onto the drywall hoist. IMG_8563.jpg
Finish hanging drywall and added joint compound
Finish sanding and put “shell construction board” on floor to protect it from paint splatter. That stuff is amazing, doesn't fail with the heavy scissors lift.
Painted ceiling and walls with Sherwin William's semi gloss Pre-Catalyzed Water based Epoxy. This paint was not cheep, but has doubled over the past year. Airless spayed everything white. Then sprayed painted the wainscot blue. Along with the HVAC duct work. You'll notice my blue theme throughout my shop.. IMG_8615.jpg
O
OldCarGuy
Painting HVAC duct work after power washing.
Removing the old HVAC unit with my John Deere Tractor. The “Shell construction board” held up under tractor load..
Replacing three large Pella dual pane windows
Install new bridge crane hoist after painting beams. Install 34 four foot LED ceiling lights. Prep floor for epoxy coating, Sherwin Williams ArmoSeal 1000 HS
Several photos of shop with equipment installed.
New Coffing four ton chain fall. Rather than running the power cable using looped Festoon cable as I did the first time around. I tidy up by using two automatic electrical recoil reels. One for the bridge and the second for the runway.
southalabama
Brewton AL
Tool boxes survive the fire? How’d you clean them?
I discovered this site years ago after having a sewage flood and having to clean up a lot of tools. Cleaning tools *****.
O
OldCarGuy
The Gerstner & Son's combo roller set consisting of R3005 Pro-Series Roller Base, B2705 Pro-Series Riser Base, and the 2613 Pro-Series Top Chest are the 100th Anniversary Editions,, 2006. Seeing that they were irreplaceable and after the factory said they would not be able to restore them. I took it on to save them. The backs were toward the main fire and the cherry veneers were burned off. After some sanding and stain, the exterior was sealed with automotive clear-coat. I was able to free up the drawers with some effort. And freshened up the drawer felt. Though the cabinets are far from perfect. The cabinets are very usable.
The three Gerstner Journeyman 2610 on top the work bench were purchased new. They replaced the three old cabinets that were destroyed far beyond repair.
O
OldCarGuy
My grinder area.
US Industries 12” by 24” three axis surface grinder.
US Industries 6” by 18” two axis surface grinder
Monaset Tool and Cutter Grinder
Deckle SO Cutter Grinder
US Industries 16” Lathe
Dake 50 Ton Press, small and large ultrasonic cleaning tanks
United Zoom Microscope
woodfor1
Wantage NJ
Hello the shop looks great I was wondering did you replace the over head crane with new steel or was the original one still in good shape. Did the heat from the fire affect it.
O
OldCarGuy
I replaced the chain hoist because the windings were shorted out. Plus I replaced the bearings in the end truck. But I didn't replace any steel beams after consulting a metallurgist.
O
OldCarGuy
The Annex
During the process of rebuilding my main workshop I crammed everything deemed salvageable throughout my other garages. And added this small 15' by 30' area as a place to unload and recommission the paint booth. Where else could I paint all the shelving, benches, machinery, tables, etc. Took two weeks to complete and another few days to fill up. The lean-to design was the easiest to complete, three walls, single sloped ceiling, add doors and it's done. Well sort of.
Basic 2 by 4 walls, 2 by 8 joists construction.
Added a 100 Amp 240 Volt sub-panel & rough in wiring, and extended air lines and natural gas lines.. then installed insulation..
Fire rated drywall
Paint interior and epoxy coat floor..
Installed door and opener...
Installed through-the-wall ducted HVAC unit
E53D55D5-4611-4ABF-A17C-A72F3D0B7FC9.jpg\
Added gutter and painted...
Built-in Shelving..
Built a mezzanine out of scrap lumber I acquired..
Built a wall rack for my 1914 Cadillac's six new the 36" by 5" high pressure tires, With a $35.00 solid maple top I came across I made a simple workbench. There's enough room to get around my Avalanche on all sides. I have six atomic clocks throughout my garage compound..
southalabama
Brewton AL
Once again I’m impressed. Your skill set is way beyond anything I can do
But
Your energy level. You must eat Wheaties.
O
OldCarGuy
But
I've always had the mindset if someone else can it, So can I..
I may be considered old, weaker, and no where near as fast. However I'm still steadfast in any project that I take on...
Craig Balzer
Colorado Springs
I know you are very selective when identifying new vehicles for inclusion to your stable. Maybe this one meets all the criteria
1935 Buick 46C -- 1 of 933. Can't be many left:
1935 Buick 46C - HOU2853
Blue 1935 Buick 46C powered by a 233 CID I-8 engine with a 3-Speed Manual transmission (2853-HOU). Gateway Classic Cars has 3622 Classics For Sale in our 20 Indoor Showrooms Nationwide.
www.gatewayclassiccars.com
Or do you already have one?
