LeeG
My water heater hasn't yet failed, but it is 16 years old and I'd prefer to do it before I have a leak to deal with. It is located in my garage, in a small (22" x 22") alcove in the corner. The opening is 1/2" wider than the water heater.
The only water heaters I can find locally are Rheem, and the only ones that fit in the space are 14" taller than the one I have now. This puts the water heater higher than the stub outs that are in the wall for the inlet/outlet pipes. I believe that the easiest thing to do in this case is to lower the platform the water heater is sitting on so that all of the connections remain at the same level. Any thoughts on that or other things I should do when doing this replacement?
I have started on making an overflow pan for this to sit in. I am going to form it from some 22g steel I have and size it to fit the opening exactly. I'd appreciate any other ideas or thoughts on what else I should do at this time.
Lee
Lee
