Technique name for fastener locking
bayseven
Sorry no pictures,not allowed at work but imagine the end of a bolt with a nut threaded on to it flush to the bolt end. Now a small set screw inserted into the threads between nut and bolt parallel to bolt effectively locking nut in place. What is this technique called?
Crude drawing. Messy blob is the set screw
Walkers
Cave Creek Az
I’d just call it silly, because there are so many better ways of doing it. It is just a one and done set up, and very unrepeatable.
Try calling it a lock screw, or a locking set screw?
Viper98912
GA
I've never seen something like this. Why would you do this? Do you need to drill a hole into the end or something before you drive in a set screw?
kwb
PNW
Problem with this strategy is that the main bolt actually can't do the right amount of clamping because you won't be able to torque the fastener properly. Might as well just use a Clevis pin
bayseven
I would never attempt this " lock?" I saw it at work and thought it was let's say ,interesting. I tried Google but hard to find something without a name. Guess it is not a common process.
floyd
MD
This looks like what you’re describing. Factory installed caster wheel assembly from an old Hein Werner floor jack.3D704C8E-F577-488B-BAA8-648A5E150C84.jpeg
kaymccampbell
Upstate New York
I've seen that on 19th century machinery. I'm not sure if it was original, or a user redesign. The ones I've seen, the pin shared the thread pitch with the shaft, so you could pin it once every turn of the nut. They all were extremely fine pitch.
ArcReactorKC
Out in the county NE of KCMO
We called it a dutch lock when I worked industrial maintenance at a spring shop. The pistons constantly unscrewed themselves from the shaft in our pneumatic actuators, this is how we stopped it. Worked well for the application.
