nameyers11
- Joined
- Nov 14, 2022
- Messages
- 3
Hello everyone, and thanks advance for reading this.
I am afraid I may have messed up my garage floor, and could use some advice on what to do before making it any worse.
It's 380 sf, 30 years old, no cracks or large damage. Kit is 4195 epoxy (gray) with 5085 polyaspartic clear, full flake (gray/black small size). Previous homeowner had installed carpeting, and therefore I hired someone ~1 year ago to grind it off as I'd read that adhesive removal could be extremely difficult. I told the contractor I'd be putting in epoxy and he agreed to leave it ready for that.
Unfortunately my life got really hectic, and I wasn't able to get to it until recently. In the meantime my mother-in-law insisted on parking in there a few times, and it got a little dirty. I also noticed that the contractor didn't really patch anything and there were significant areas that needed it. I thought I would patch, then grind the patches off, as well as the few areas where some tire marks/grease seemed to be an issue.
I foolishly attempted to do this with a 4" grinder and a turbo cup wheel. Looked fine as I was working but afterward with a light from the side I saw this.
I realized my error of using the 4" grinder, and went to Harbor Freight and picked up this 7" grinder and cup wheel.
I then tried to use it on a separate area I had applied a vinyl concrete patch to, and noticed the same issue (creating grooves in the surface).
So, at this point, I'm not sure how to proceed. I know better than to try to "learn" with the 7" grinder on those areas I messed up before with the smaller one. I am no expert but I kept it very level and moving in circles the whole time with no added pressure, but it just ate into the surface almost instantly. Based on the videos I watched, and research I did, I expected it to be a pain using the 7" angle grinder, but would just be a matter of taking my time. I'm guessing the problem is related to the cheap equipment (heavy-17+ pounds, high rpms-8500 with no speed control), the fact that the concrete is soft/already ground once, and my lack of grinding expertise.
I wonder though if it is as bad as I think, when I look at it in normal light from above it doesn't seem too bad?? I've seen pros elsewhere on here say that 1/32" grooves won't telegraph through with full flake and these are that or less.
I contacted another contractor and he's asking $6/sf to grind and patch and that will defeat the whole cost savings of doing it myself.
Any thoughts? Would renting a walk-behind be a good option perhaps? Renting a different 7" angle grinder/different cup wheel? Maybe try to epoxy patch the grooves? I'm really hoping the wiser people on here can steer me in the right direction, so I don't make this worse.
Thanks,
Nick
Thanks,
Nick
![IMG_1068[1].jpg IMG_1068[1].jpg](https://www.garagejournal.com/forum/data/attachments/1621/1621984-f4047b1a8cbdf6849156576381bd0e71.jpg)
![IMG_1071[1].jpg IMG_1071[1].jpg](https://www.garagejournal.com/forum/data/attachments/1621/1621985-19c52d02081e2026bff71a14468ca21c.jpg)
