Is it always safe to use an impact on a strut nut?
When I tightened my strut nut with a medium breaker bar, you can feel after it snugs, the flexing of rubber (assuming that is the strut mount).
Some manufacturers actually recommend using an impact; that it is the only way to tighten their product like this company -
However on Toyota and Lexus struts, there is a groove on the strut rod and mount that prevents the rod from rotating in relation to the mount. So in this case is it still safe to put the impact on the strut rod nut? Can you damage the strut mount?
I have a strongest Milwaukee Lithium Ion Impact which boasts “1400 ft-lbs of nut busting torque”. I don’t want to rip my strut mount apart; but at the shops you see them use the pneumatic impact (which is a weaker impact) on the strut nuts all the time.
