Bent handle (FLEX HEAD) ratchets….
bimmer630
I’ve always wondered why bent handle flex ratchets only came in 3/8” drive…
Older catalogs from Mac used to list them as “ratchets for spark plug service”
Is the bent handle simply for clearing the side of a cylinder head when doing plugs? Or is it so the bent part of the handle is more perpendicular to the extension, and offers a more straight-on attack on the socket (reducing broken spark plugs)??
If the latter is the reason for the bent handle, that fully explains why we don’t see the bent handles on 1/2” or 1/4” ratchets.
Either way… I thought it would be an interesting discussion….
anndel
Hawaii, USA
I have 2 Snap-on 3/8" bent handle flex heads and a Snap-on 1/2" bent handle flex head. I believe others have them, Sorry for the blotches, I had to hide my name.SO BENT HANDLES.jpg
Oldsmobile
Harrisburg PA
Yes, I also have one of those SK bent handle 3/8 ratchets, and it's my go-to for brake calipers as well. But I never thought of why there wouldn't be a use case for bent 1/4 or 1/2. This thread got me thinking, though, about a 1/2 Wright that I bought for ten bucks at a flea market. I haven't had an absolute need for it yet but maybe someday it'll be just the right (Wright?) tool for the job.
Wrench97
Southeastern Pa
They started out for use on spark plugs back in the 70's, they worked well to get around smog pump piping, steering shafts tighter engine bays. After using them we found they also came in handy for other things to.
dnschmidt
Phoenix, AZ
It started with spark plugs. I have one branded Champion Spark Plugs and the reason is back in the day we used pushrod engines that had the spark plugs on the sides of the engine up against the fenders. The bend handle made it easier to work around obstructions. Clearly they can be used for other things but my feeling is that small cordless impacts and swivel impact sockets replaced these for most applications such as the previously mentioned brake calipers.
bimmer630
Im not THAT young to never have worked on a pushrod V8 or V6!!
I still see a few now and then, too.
turnthewrench 2.0
FL
I agree, the bent handle feels more “right” in a lot of situations.. I use them more than the straight ones.
Interesting on the texton
Yep. The situation dictates the usefulness.
They’re useful tools in a number of situations, especially when you are working “back to front” with the socket facing you, rather than away from you.
My “go to” tool for removing brake calipers!
Same here. I use the locking flex head Carlyle.
errrr... a bit before that, actually. the Champion "Plug Master" was actually manufactured by the New Britain Machine Co. (Kilness patent.)
The model CT405 had a straight handle, but a flex head. The other models had bent handles as well as the flex head.
F-22
I have some "Kreator" ratchet that has a slightly bent handle.
72 tooth, and it's actually really nice to use. The handle offset is just enough that you often don't need to use an extension. I assume it's Taiwan made?
joel63
Central FL
Snap- on has one similar to yours that which they refer to as an off set handle.
FHOF80A Very handy.
Chrome Vanadium Cody
I’ve been using an unbranded 1/4 drive version of this in my junkyard go-bag for years with no complaints. Nothing fancy about it but it just works.
Have my eye out for one of these. They look awesome
finn
The UP, God's country
Back in the 60s, my cousin had one of the Champion spark plug wrenches, as we called them back then. It was extremely useful and functional.
Years later I picked up a couple similar to that Champion wrench. I think one is a SnapOn, and the other is an SK.
Unfortunately, or. maybe fortunately, they don’t get much use anymore as spark plug changes on modern engines are an every ten or fifteen year event, not every six months like in the days of leaded fuel and before platinum plugs.
Scottie S.
Hello everyone.First time poster here.I couldn't help but comment on this discussion as I just used a bent handle flex head a couple of weekends ago.A Craftsman CMMT99439.This is a 72 tooth ratchet made by Stanley Black and Decker from China or Taiwan and sold at Lowes.I picked it up at a swap meet for $20.00 brand new.I installed a set of plugs in my "81 Chrysler Imperial.That year Imperial is V8 powered.And with all the maze of vacuum hoses,braces and smog garbage under the hood,the bent handle flex head comes in very handy.The bent handle gives you just enough leverage to back the plugs out without skinning your knuckles.With the sparkplug socket and a few extensions attached,the bent handle is clear of all obstructions.You just ratchet the plug out effortlessly.And then to reinstall I use a stubby flex head to start the plugs and then back to the bent handle to finish the job.Once you use a bent handle flex head changing plugs,you'll never go back to a standard straight flex ratchet.
