Craftsman drill press original?
Zrxrunner
Eastern Iowa
Local posting for $85. Seems like right in the ballpark to replace the old clarke metalworker floorstanding press i have now. From the sole picture on the listing, do some of you experts think its unmodded? Looks like only 2 handles arms to raise and lower? Usually 3, right? Pretty sure im gonna try to arrange a look/pickup if its still there this weekend. Thanks
FrankLee
seMI, 48317
That is a 13-1/2" Craftsman 80 bench model converted into a floor-standing drill press. There was a floor standing version available from Sears for a few years, but it had a larger base than that one and the column was not that tall.
The 13-1/2" machines are every bit as capable as the 15-1/2" machines. The bearings are identical. The quill diameter is the same 1-5/8". The spindle diameter is the same 5/8". The step diameters of the spindle pulley are the same. Parts are just shorter/smaller. Quill feed is 3-1/8" vs 4" on the larger DPs.
That one looks to be repainted. The head trim panel is not present. IF the head trim panel was not installed at the factory, it is a '52-'53 model. It's possible that the PO may not have reinstalled the panel after painting.
There is something weird about the chuck; it's not original.
Jim C.
Looks like it’s missing the decorative hammered aluminum head band. I have an original unrestored 1948 model. If you need photos of any component on the machine for comparison purposes, just let me know.
Jim C.
exmaxima1
Midwest
I've seen keyless chucks similar to that on older Dunlap presses---maybe it was somehow adapted to the JT33 spindle on this Craftsman DP. I wouldn't buy the press unless I knew if that chuck could be replaced with a keyed version.
Z
Zrxrunner
Eastern Iowa
Thanks for the tips ,fellas. I might at least go take a closer look, but if it's frankenstein, i'll probably pass. I already scored a project floorstander similar to this that is in the long line of projects to complete
subroc
Dover, NH
The price might be a bit high...well, it would be for me. I have a 13-1/2" in the basement. I like it. I use it. The 15 i use is in the garage. I have others/projects as well.
I am not sure I would want or use a bench top base on a floor model. Others might differ. Maybe sandbag it? Maybe a couple 25lb weight plates?
Certainly worth a look. Anyway, if you were looking to add a 13 to your line-up and you could get it for a better price might be worth it.
Good luck whatever you decide.
JEFinCLE
Medina Ohio
Historical accuracy? Just curious why you would replace a keyless chuck with a keyed one. I have a Delta keyless chuck from the late 30s on my Delta Radial. I put new Jacobs keyless on my my vintage 14" Delta. I love keyless chucks. Maybe there's something about them I don't know, but at least for woodworking, I prefer them.
exmaxima1
Midwest
Looking closer, that might not be a keyless chuck since THE KEY IS HANGING ON A CHAIN. Sorry about the confusion.
subroc
Dover, NH
Looks like he just stuffed it in the hole and tightened the clamp on the base. I would certainly be interested in how the upper and lower pipe are joined.
whateg01
doo dah, kansas, usa
They **** for hole saws. I learned that the hard way. They self-tighten.
Z
Zrxrunner
Eastern Iowa
Yeah, notice the pipe difference. Might be an easy convert back to bench top just removing that, but wouldnt pay the $85 for a bench model. Already have obe of those too
