HamAndEggs
This is sort of related to my other thread, but its a whole separate question so I figured I'd make a new one.
I'm getting some plumbing done soon, and part of that is to make this pipe that is attached to the TRP valve on the water heater much, much lower to the ground so I don't fall getting around it. One day I'll grab it by mistake and it will be a bad day (Actually, I already put my foot through the ceiling here when I stepped on a FENCE PICKET SOMEONE PUT UP THERE)
Here it is.
While looking it over today, I realized that its not actually even resting on anything. Its directly on the sheetrock
I thought it went down into a nearby wall, but no. It runs the entire length of the attic on the sheetrock (Lucky a few top plates along the way) and then down into an exterior wall. So if you grab it and put weight on it, all of that goes into some sheetrock.
So, I strapped it up with some hanger strap, and removed the vertical piece (Temporarily directed TRP into the drain pan)
That's when I found, it has water in it... The water smells like you've never smelled before, so I assume the entire run is clogged up and not draining. I set my water heater to the hottest setting and watched the TRP, no water came out. So it must be old
I am 99% sure it has complete positive slope, but I'll dig around and check some more later. So it must be clogged up. I suppose I could drag a compressor up there and try and blow it out, or get a shop vac on the other end
Question here is, would it be a terrible idea to just extend the TRP down into the drain pan? The drain pan runs to the outside with 3/4 PVC. The other benefit of going into the drain pan would be that it would then fill the pan, and trigger my water detectors and I'd know something was up. Right now it could be draining all day long, and I'd never know!
Would love your thoughts
Here it is.
I thought it went down into a nearby wall, but no. It runs the entire length of the attic on the sheetrock (Lucky a few top plates along the way) and then down into an exterior wall. So if you grab it and put weight on it, all of that goes into some sheetrock.So, I strapped it up with some hanger strap, and removed the vertical piece (Temporarily directed TRP into the drain pan)
