Madjik Man
- Joined
- Dec 3, 2015
- Messages
- 1,527
After catching some flack in here about tap handles being inadequate, I grabbed these:
lol, get mocked, questioned and shamed into buying more tools.
A few recent purchases.
Yes, Nepros.Those 6pt DBEs are beautiful. Assuming Nepros?
Nice haul. What’s the snap on tool at the top of the picture?A few recent purchases.
That tool is used to replace ratchet or screwdriver handles. It does both the removal and insertion of the ratchet head or screwdriver blade into the handle.Nice haul. What’s the snap on tool at the top of the picture?
That’s awesome!That tool is used to replace ratchet or screwdriver handles. It does both the removal and insertion of the ratchet head or screwdriver blade into the handle.
Part number ?That tool is used to replace ratchet or screwdriver handles. It does both the removal and insertion of the ratchet head or screwdriver blade into the handle.
Nice! You're going to like those pliers.A few things today.
I have a couple of those needle file handles. They are really nice to use.A few things today.
Only $130! That actually sounds cheap for Snap On. Sacramento isn't that far away either for me
And I’ll be the guy to ask: “What are those angled pliers at the top with the chunky handles?”A few recent purchases.
Long ago discontinued pliers. They are for grabbing rubber fuel lines. Absolutely indispensible when working on small gas engines like lawnmowers, chainsaws, leaf blowers, line trimmers, etc. Makes removing and installing the rubber fuel lines much easier. There are two different sizes for different diameter fuel lines. Here is a better picture.And I’ll be the guy to ask: “What are those angled pliers at the top with the chunky handles?”
I have that same pliers set. They are made to disconnect the quick connect fuel line connections for 3/8 and 5/16 fuel lines. I'm sure they work good at your purpose also though. I hope I did not look at the picture wrong and make a mistake, forgive me if I did.Long ago discontinued pliers. They are for grabbing rubber fuel lines. Absolutely indispensible when working on small gas engines like lawnmowers, chainsaws, leaf blowers, line trimmers, etc. Makes removing and installing the rubber fuel lines much easier. There are two different sizes for different diameter fuel lines. Here is a better picture.
Do you know who the OEM was?Long ago discontinued pliers. They are for grabbing rubber fuel lines. Absolutely indispensible when working on small gas engines like lawnmowers, chainsaws, leaf blowers, line trimmers, etc. Makes removing and installing the rubber fuel lines much easier. There are two different sizes for different diameter fuel lines. Here is a better picture.
Schley, I beliieve. I'm not the one you asked, but I believe I am right.Do you know who the OEM was?
I've never dealt with quick connect fuel line connections, but I believe you are correct. I just got them to remove and install the fuel lines on my small gas engine equipment. They have worked very well for my purposes. I saw a picture of them and thought they would work great on small fuel lines.I have that same pliers set. They are made to disconnect the quick connect fuel line connections for 3/8 and 5/16 fuel lines. I'm sure they work good at your purpose also though. I hope I did not look at the picture wrong and make a mistake, forgive me if I did.
Yep. For GM specifically. They sold a similar larger set for fuel and AC couplers on Ford/Mazda. And even yet another one for heater hoses.I have that same pliers set. They are made to disconnect the quick connect fuel line connections for 3/8 and 5/16 fuel lines. I'm sure they work good at your purpose also though. I hope I did not look at the picture wrong and make a mistake, forgive me if I did.
Yep, correct I have the A/C connectors and heater hose connector pliers also. They work greatly for me. They make them in a straight version also for 3/8 and 5/16. I have them. I don't know about straights in the larger sizes.Yep. For GM specifically. They sold a similar larger set for fuel and AC couplers on Ford/Mazda. And even yet another one for heater hoses.
I appreciate it. I’ll be on the lookout for them. The grips look identical to the OTC Fuse Puller pliers.Long ago discontinued pliers. They are for grabbing rubber fuel lines. Absolutely indispensible when working on small gas engines like lawnmowers, chainsaws, leaf blowers, line trimmers, etc. Makes removing and installing the rubber fuel lines much easier. There are two different sizes for different diameter fuel lines. Here is a better picture.
I was given an engine house from work that did not have a hydraulic ram. I couldn't decide what I wanted to do with it so it sat in the barn. Well while laying in bed with a sick toddler on Black Friday, I ran across an Big Red 8 ton double pump ram for $70 on Amazon. I finally got to install it today.
Took me a bit to unravel the spell-checker carnage engine "hoist"Er... what's an engine house?
I think you are going to be pretty happy with that purchase!
These are rebranded SK LP90 ratchets.Arrived here this past weekend. Made in USA.
Steve
