Shop Compressor -- turn off when not in use?
Do you turn your compressor off when not in use?
  • Yes, I turn it off or unplug it whenever it is not in use, or when it's left unattended
    Votes: 95 84.8%
  • No, I sometimes leave it on when not in use, or when it's left unattended (overnight, etc.)
    Votes: 17 15.2%
  • Total voters
    112
welder4956
Birmingham, AL USA
I always close the valve at the compressor and switch the power off (unless I forget). A few times I have been outside and heard the compressor kick on when I forgot to switch it off. I don't want it running if we are out of town or gone for several hours and chance a meltdown or fire.
cabranch47
Louisiana
My compressor is wired with a relay to the lighting circuit in the shop, no light, no compressor.
IMO you need to shut off the compressor as things can fail. Air hoses pop, diaphragms in pressure switches fail and leak, pressure switches stick on, PVC air lines rupture and the compressor runs until you go out to the shop.
Do you leave your air hoses connected? I had one blow and the compressor ran long enough that when I got home the pump was smoking!
I too have my compressor on a relay wired to my shop lights. Works great and no worries about failure from unexpected leaks.
alex71
SE Florida
always off! Just turning the valve off at the tank is not enough. I had an IR 5HP compressor blow the factory compression fitting from the head to the tank, causing it to run continuously over a long weekend. I guess 100% duty cycle is as advertised, as there was no damage. Just a lot of heat. Changed the oil, replaced pipe and fitting and it still runs to this day... But it is always turned off at the end of the day.
peter94
Best to turn it off, if you have a line burst or something decides to leak overnight, your compressor will run for hours until it is noticed. A friend of mine has a hobby shop that he uses on weekends, didn't turn his compressor off, something started leaking (in a major way) and the compressor ran all week. Now the motor turns on, the compressor spins, but builds no pressure.
Citation
Indy
I turn off and close an output valve. This is a belt drive 120V compressor. I don't drain the tank beyond what is needed to get the condensation out (ie not drained to zero). With the outlet valve closed the compressor generally will hold pressure for weeks so when I turn it back to on ("auto") it generally does not need to immediately turn the pump on.
PoorUB
Fargo, ND
Nobody has a leak until they do
Yup! My piping for my air compressor didn't leak. All new quick disconnects that didn't leak. I could shut off the compressor and go on vacation and come back and the gauge maybe dropped a couple PSI over a couple weeks. It was almost unbelievable!
Came home to the compressor running and a blown air hose.
My set up now has a small leak. It takes a bit over a week before the system leaks down to run the compressor, and that is with the auto drain on a timer left on. I still shut it off.
txvwnut
Bedford, Texas
I try to turn mine off when not in the shop. I went out of town one time and when I got back my neighbor to the shop I was renting said he heard my compressor running non-stop. All of the units had a master disconnect at the meter so he tripped it to shut the compressor off. I don't know how long it had ran but the oil was rather burnt. I thanked him for the assist, changed the oil in the compressor and fixed the blown hose on a reel and was back in business. That compressor ran for about 15 years after that before it tossed a rod.
NUTTSGT
Northern Central Ohio
I just close the ball valve that pressurizes the system. Compressor will kick on once in a great while to maintain pressure in the tank.
brownbagg
had a older model. it was left on and when it fired up, the motor caught on fire, just old, shorted out. so I now throw the circuit breaker when I walk out
whateg01
doo dah, kansas, usa
I've always been told that circuit breakers are not meant to be used as switches and doing so will shorten their life. No idea how accurate that is though.
u2slow
BC
Make or breaking under load is harder on them than without load.
Breakers made for the purpose are marked "switching duty" or SWD.
Skellyii
KC Area
My old compressor setup two houses ago leaked, so I got in the habit of always turning it off when I wasn't using it. I also traveled for work a lot, so I might not use it for a week or two. Next house, no leaks, but I had gotten in the habit of turning it off when not using it.
Just setting up things in my new (to me) garage. Will probably turn it off when not in use, since the new garage is a lot bigger and the sound of the compressor will echo off the walls a lot easier. Also, I've gotten used to using more cordless tools. ;)
mikedodge
I always shut mine off and drain them when done unless I know I'm using it again shortly after. Like others said why risk something going wrong.
I use a small compressor for things like filling tires to save having to run the big one.
