Shop security-12 volt radio
bluedog225
Texas
I’ve got my little shop set up with a 12 volt battle born battery, panels, and charge controller. Works great. Basic lighting and keeps my battery packs charged. I only charge them when on site.
I’ve been looking high and low for a cheap little 12 volt radio. Something that runs off a cigarette plug. I got zip.
Before I get all ghetto and pull a head unit from an old Chevy, I wondered if anyone knew of a source.
I’d like to avoid anything with a lithium ion battery. I plan to leave it on all the time for security and would prefer to minimize the chance of fire.
In the old days, they were common. Maybe the world has moved on.
Thanks
Youngandfree
VA
bluedog225
Texas
Nice find. Thanks.
I’ve actually got two of the Sangeans. They are good radios but the tuners drift.
jack stand
Lakes Region Maine
Most of the major battery tool makers have pretty good radios.... if you're already set up with cordless. I drag one of my Makita radios everywhere I'm working but I've got dozens of their tools and batteries anyway.
duneslider
Riverton, Utah
What about a 12v clock radio. If you are just looking for something to leave on when you aren't there it doesn't need great sound right? Should be a handful on amazon for not that much.
Fasthotrod
Oklahoma
For what it's worth, a friend of mine is a cop and we talked about shop safety and trying to deter people from breaking in because it sounds like someone is home.
His advise: Don't leave a radio on 24/7. That's a sure sign that nobody is there. Burglars don't fall for that.
bluedog225
Texas
I like the idea but I’m coming up empty looking for a 12 volt to 3 volt dc adapter.
Citation
Indy
How handy are you with wiring? If you are comfortable doing the wiring something like inphx found or a variable version is good.
Here are 10 for $14 (just the circuit, no wires or housings)
I've used these before. The upside is they accept a wide range of input voltages and you set the output to what ever you need.
If you just have a 12V car socket then something like this might work
This is something like the old universal adapters so you could power your discman or what not in your car.
Citation
Indy
Also, if your batteries are big enough you could consider a DC to AC inverter. It's not a very efficient way to power a device that ultimately wants DC voltage inside. However, it does open up a lot of options.
Personally, I think I would do something like a basic car stereo or perhaps something like a 12V powered amp (an old Lepie lp2020 amp) + speakers + my old phone that has an FM tuner. Still, my needs etc aren't the same as yours.
71goldss
Northern Calif
I used to have an old car head unit hooked up to one of those cheap Harbor Freight trickle chargers in the garage. Worked out great for years, but I was never really sure if I should have safety concerns using it for that, so eventually I upgraded to a Denon receiver, bought cheap off eBay. I only had it on when I was out in the garage working, and never unattended.
