Innovate1
Have a safe room/tornado shelter under my porch. It's an 8' x 18' room with access from the basement. Ceiling is hollow core slabs with EPDM over that and then a poured porch. Get some slight condensation in cold weather around the top edges. Thinking some insulation would be good to eliminate condensation and keep the extremes of heat and cool out. Looking at foam board - xps type although I suppose I could use something cheaper since strength and crush resistance isn't an issue. Then I would like to cover it - probably some plywood. I could glue up the foam but thinking tapcons for the plywood. I could attach blocking to the concrete and nail the sheeting to that but it seems like it would just make things more difficult with lots of foam cutting to fit between the blocking. Want to run the insulation down the walls a few feet. The ground outside goes within a few inches of the top so only have big temp swings at the top. Planning a board around the bottom edge of the wall foam so all the foam is covered. 2" on the ceiling and 1" on the walls. A couple lights on the ceiling and conduit for wiring. Was thinking I would repeat that over the plywood but I could run the wiring behind the plywood and it would look a lot cleaner. They make some texture coatings for foam which might be an option. Any suggestions on this?
