Rabid Badger
- Joined
- Apr 2, 2018
- Messages
- 1,338
Cool.....so when do you start the Hadron Collider battery pack?
Aluminum has low resistance and conduct heat well, and produces a non conductive oxide when heated to weld temperature.. aluminum is out.
Aside from Nickel strips, I was reading on one of the forums there is a Copper/Nickel alloy strip which has better than Nickel conductivity but looks promising to use instead of pure Nickel or copper strips. Other have tried pure copper but it has little resistance (welder need resistance to produce heat) and conducts heat away from the weld area to fast.
Have you used it much since?So I bought this battery spot welder from Banggood. About $60 with shipping.
Not shown is a USB-A to USB-C charging cord and some 0.1mm x 7mm nickel strip. (I would recommend 0.15 or 0.20mm x 10mm or 15mm. I did my testing with 0.15mm.)
I have only done a couple of batteries, but it works as described. (Those nice looking gold connectors are called XT150 - latest high current from the RC world.)
The good
- Portable
- Includes internal batteries
- Reasonably price
The bad
- Instruction manual in Chinese (simplified version in English on the back of the unit)
- Very short wire (the copper "barrels" are actually encased in clear shrink tubing)
Battery welder in action (not me).
Only used it a couple of times. Been sitting for months.Have you used it much since?
I bought a similar one and it worked well for a few welds, and is now useless.
I want something decent to repair the occasional dead cell in tools. But I don't want another project. A day kit would be okay but I don't want to have to randomly put parts together.
