Again, one gallon of concentrate makes TWO gallons of pre-mix. And frankly, I don't get the "clean container" thing. If you need a gallon, pour half of the concentrate out of the jug, then half of the water. This isn't nuclear science. If the actual mix is 51/49, your engine isn't going to lock up. And this may be sacrilege, but I've never used distilled, just tap water. Been doing that in every vehicle I own since the mid-1970s. Haven't had an issue in half a century.Not that simple. I topped of the recovery tank in the old Ram. Premix was $8.** at Walmart. Full strength was, I think, ~$10.** or $12xx / gallon, plus distilled water was about $1.25.
The truck needed about 3/4 of a gallon. The math says it cost ~\$8.00 to top off the reservoir with premix, but would have cost something like $11.xxor $13.** to use concentrate, plus find another clean container to do the mixing.
Plus, the distilled water is at the other end of the store, and they’re usually out of stock.
I am 100% sure he understands that math.Again, one gallon of concentrate makes TWO gallons of pre-mix
Maybe my grandson will inherit that second gallon of concentrate I mixed.I am 100% sure he understands that math.
If I don't need a second gallon, it means the first one takes all the cost. If the second ever gets used, then you can argue the first cost half.
It's the same fallacy that gets people to buy huge bulk packs of food at bj's/Costco when they don't need it. If you end up throwing a bunch away, your cost per unit is a lot higher. Overbuying is expensive
It's vintage grampy!Maybe my grandson will inherit that second gallon of concentrate I mixed.
I’m sure he’ll appreciate that I saved $3.00.
I've got shelves in the shop for all my automotive fluids (and filters). The cars, trucks, and tractors get regular changes. There is no unused extra.I am 100% sure he understands that math.
Except you'd still have half left if you mixed it yourself so it would have been more like $7 for that top up and next time you don't need to buy any so you're ahead of the game.
I haven't had overheating but my truck has had various cooling system bits fail and piss it out everywhere. Big one was the EGR cooler failure, second biggest was the reservoir cracked. Other ones were just junction blocks and various ports and o rings and such. Still a loss of coolant requiring top ups or complete replacement after repair.Exactly, I don't think they sell coolant in quarts, so if you only need a gallon, you will have 2 buying full strength, so will have a jug of 50/50 sitting around for who knows how long (do modern cars in good shape even overheat anymore? I can't remember the last time I had to add coolant to a car built since the 90s).
About 9 years. 520k now. 426k on it when I bought it almost 2 years ago.How old is the truck? The only vehicle I can remember adding coolant to other than replacing old with new is my 1969 Land Cruiser. Agree with KEH I think the cooling systems are just a lot better today (well really the past 40-ish years as none of my 80s cars were ever much of an issue on coolant either).
Which color is the engine?About 9 years. 520k now. 426k on it when I bought it almost 2 years ago.
It was red when it came from the factory. Why?Which color is the engine?
PS.: EGR coolers are real MOFO's, that's the hardest modern engine component to engineer (within a price point). The new Navistar engine (S13, developed by Scania) doesn't have EGR cooler, everyone in the industry is curious about how it will play out.
Good color... it means Cummins.It was red when it came from the factory. Why?
No it doesn't. Not in this case.Good color... it means Cummins.
Isn't this a semi in North America? What truck and engine are they?No it doesn't. Not in this case.
Yeah it's a Mack though. The engine is an MP8. Basically a Volvo D13 painted red.Isn't this a semi in North America? What truck and engine are they?
Gotcha, now I remember you commenting about I-Shift (cough... mDrive) earlier. It's a good powertrain.Yeah it's a Mack though. The engine is an MP8. Basically a Volvo D13 painted red.
The more stuff I replace the less red it gets. Lol.
Yeah everything I've had go wrong has mostly been age, abuse, or my ignorance. If it hadn't lived such a rough life it's first 400k a lot of the repairs I've done wouldn't have needed done.Gotcha, now I remember you commenting about I-Shift (cough, mDrive) earlier. It's a good powertrain.
Yeah I'd say all of the above. Lol.Oh a commercial diesel, that makes sense. On fire engines we did have to top up from time to time throughout the year. Don't know if it is the nature of the engines, the kind of use they see or simply the volume of coolant which makes small losses more apparent compared to light duty cars and trucks, probably some of all of the above.
Good point. When I think about it I don't remember the last time I bought any antifreeze. It may have been five years ago. I certainly do not need two gallons laying around if I just need a top of!Exactly, I don't think they sell coolant in quarts, so if you only need a gallon, you will have 2 buying full strength, so will have a jug of 50/50 sitting around for who knows how long (do modern cars in good shape even overheat anymore? I can't remember the last time I had to add coolant to a car built since the 90s)
Service interval for coolant is 10 years or 150000 miles on the Jeep and my other, 12 year newer Ram.Or use it towards replacing the coolant that's been in there the last 7-10 years thumbs
I can see why there's a need for pre mixed.
Murphys law comes to play when I try to buy just what i need. If i bought the pre mixed to save not buying double the amount I need I'd end up needing that second jug. If I bought concentrate and mixed it I'd never use it again.
