chad s
I have a small project where I will need to make a quantity of 24 cuts in 304 stainless steel bar that is solid 3/4" by 2-1/2" stock.
I do not have a large band saw, chop saw, or cold saw.
I do need decently nice cuts, that are good vertical 90 degrees, so I can weld the 45 degree mitre cuts to form corners.
I think that an abrasive wheel chop saw, while cheapest, may be dreadful for 24 cuts.
There is the evolution Rage 2 dry saw, but they rate it for a max size of 1/4" wall tubing. I dont care if the blade cuts the 24 cuts I need and never makes another cut, but to ruin it on the first cut would be a disaster. If it will cut 1/4" wall, I dont see why it wouldnt cut solid stock thats 3/4" thick, just take longer, and make more wear on the blade per cut. Is this thinking out of line?
The last option is one of the inexpensive 4x6 band saws. Can I expect to get one of these to make a decent 90 degree cut without the blade wandering and going off coarse, without a ton of time modifying and adjusting it? The cheap bandsaw is really the route Id least want to go with, unless it is absolutely necessary.
Any guidance?
Any guidance?
