TireTracks
Yeah I knew which ones. They look like the 70's Snap-On screwdrivers. I've seen them and they are junk. I just posted those because they are such a dreat buy
Ah. Then i will stay away.
Flex Drive Compression Tester
PASS
This is very nice quality for the price. I don't know how accurate it is, but is is very repeatable.
In my experience, wooden handled hammers do not qualify for lifetime replacement. Same goes with the rubber mallets. I have broken both and got this explanation when trying to get a replacement.
The fiberglass handle (min-sledge) and plastic (dead blow as opposed to rubber mallet I guess) ones do qualify though.
PASS
Ughh.. That ticks me off. I spent $40 on a new one a few weeks back from Advance Auto. And I actually had another old one, but didn't have the right metric fitting to make use of it, so I bought a new one. Obviously I would have just bought that $8 one.. If anything just for the fittings.
Big box part stores' quality has suffered whereas Harbor Fright has gotten better. They're p'urt'near matching now.
Of course, Harbor Freight doesn't sell brake rotors...
Worcester Massachusetts store told me that when I brought in a rubber mallet which had broken. Used it to set my paver stones for a walk way (doesn't take a significant impact) and it broke about 2/3 of the way through. Brought it back and they said that wooden handled tools do not count. I didn't complain because it was only a couple bucks. I also didn't buy another to force a replacement.The warranty on their site says it has the lifetime replacement. The guy at HF when I bought it reminded me that it came with a lifetime warranty also. Where are you getting this from? I'm going to be pissed, because that's the only reason I bought it.
Their website does say it has a lifetime warranty though, as you mentioned. I may purchase another now and just print out the website if it does break again.
I've had the same experience. My buddy has a Snap-On tester that I want to use just to compare the numbers. The HF is def repeatable though.
The "hot knife",$12.95 os is a pass. Cuts 2" foam like butter,even complex shapes around switch and junction boxes.I'm useing it to cut foam to fit between studs and trusses.
http://www.harborfreight.com/3-ton-super-heavy-duty-floor-jack-34271.html
PASS! Works great. I have the yellow one, though.
Electric Pressure Washer - Epic Fail
I made the mistake of buying this turd a few years ago and it broke the second time I used it... not that it worked very well the first time, either. Complete ****.
I was just in the store the other day and a guy was returning the pressure washer. He said he was on the 3rd oneYou'd think he would have got the hint the first time..
I was just in the store the other day and a guy was returning the electric pressure washer. He said he was on the 3rd oneYou'd think he would have got the hint the first time..
If you have the warranty, why not?
7" Multipurpose Stainless Steel Scissors
Item # 97042
Recently I epoxy coated my garage floor. For the first half of the floor I did the "chemical clean / scrub with a brush / rinse / repeat" procedure for the prep (as specified in the epoxy kit instructions). It took 6 or 7 "repeats" to get it ready for coating. I decided that was too labor intensive. For prepping the second half of the floor I bought a HF 4-1/2" diameter diamond "turbo" grinding wheel and used my angle grinder to remove all the heavy deposits. This wheel is a BIG PASS (just make sure you wear a dust mask when you use it). It does a great job, 200 square feet on concrete cleaned and plenty of wheel left. They also sell a 7" wheel (if your grinder can handle it).
Item # 97042
Picked these up to get me by while i see if Matco will warranty the ones i have from them, or if i need to send these to pops to sharpen up on his scissor sharpener. Initial impression is that they are pretty well built. They cut the package they came in very easily, as well as a few small tests at home, we'll see how they cut the hydraulic hose at work on monday. for today they are a PASS
Over-sized Low Profile Creeper - 67449
Used it on a my last oil change. worked great. Comfortable to lie on, and swivel caster rolled smoothly. Catch it on sale for under $20, and it's a great deal. It's a Pass
Just picked up one of those for $17 with a coupon and have rolled around the garage a bit. I'm 6' 2 and about 150lbs and it seems to work great for me. I think I'll like the storage on the sides.
I've had one of those for about a year. Only used is a half dozen times so far but it's worked great. Though I've lost a bit of weight recently I was up to 320 lbs when I was using it and never had a problem. At 6'4" I wish it was a bit longer but I certainly can't fault the creeper for my height.
Nix,
I just saw this in an add, and was thinking the same thing about its length. I'm 6' 5", 275#. Is your **** on it at all, or does it end at your lower back?
