Looking for a quality “third hand” soldering holder.
MarvinBerry
Enchantment under the sea - NJ
For something a little different check out a panavise. If that's too spendy Bessy makes a solid knockoff for about $25... or at least I think I paid that for mine a few years ago.
Ultimately you probably want both styles... clip arms for wires & panavise for heavier parts like transformers & PCB. Or at least I use both all the time.
Steve_P
I have this one. It's easy to install and remove the arms as necessary, and has a light and magnifying glass. I don't do that much soldering, but I've used it a few times and it's 1000X better than the POS old HF unit I have with the wing nut tensioned arms and two alligator clips - that cut into the wire insulation.
WWheeler
Middleofnowhere USA
Lisle 55000 Magnetic Soldering Clamp is the only one I ever use any more. It works in the smallest spaces under the hood or under the car/truck or wherever else I need it. The base and each of the arms have strong little magnets so they can be positioned however and wherever I need to hold two wires together for soldering. If there's nothing ferrous to stick it onto nearby I can often get away with using a pair of vise grips clamped to whatever.
I don't have as much use for one on a workbench as I do with being able to use it wherever rodents got to on today's new environmentally friendly and apparently yummy wiring in newer cars/trucks. This little clamp does both rather well.
G
GophersGarage
Ontario Canada
I am looking for wires to hold up not heavy items.
I have this and good for car repair but I wanted something a bit more for my bench.
ecotec
I have these two styles and the old fashioned helping hand style with the cast base and the clips and the magnifying glass…
w.hansen
Got two they work great. I did use heat shrink on the clamp ends some times the teeth are alittle aggressive on the wire insulation
Schirmer
The most useful 3rd hand I've seen for soldering wire is the "Assenmacher WAC15 Wire Soldering Clamp" I'm not 100% sure that's the correct spelling, but it's close enough that google should find it with little effort. It's ~50$, and well worth it.
whitesco
Pittsburgh, PA (ish)
It may not meet your quality requirement but it's been plenty adequate for me given the price point. The magnifying glass maybe isn't the best clarity but that could be my aging eyes:
tarbellb
Oregon
Really easy to make from the coolant tubing, base can be plywood.
Where you really want to spend your time and money is on the clips, those can vary from great to absolute garbage.
Also, a fellow GJ member uses surgical sponge holding forceps, you can find some nice used models on Ebay- HERE
ecotec
I find Panavises at estate sales. I have 4 of them in three different configurations. I have 2 of the round Panavise bases, too.
I do not remember where I learned about the yellow off brand base with the flexible arms with the alligator clips… maybe Garage Journal… but I am pretty sure that I bought it on Amazon. It was years ago.
Anyways… I paid way more for the yellow base with the flexible arms, than I paid for all of the other Panavise stuff put together…
merkyworks
Texas
I have this one as well, took it off that base and put it on a mag switch base.
jonesg
northern Maine/
that assemnacher looks clever,
I just use alligator clips and copper grounding wire or clothes hanger wire.
Most of my work is done in engine bays on the car.
PCMusicGuy
Houston, TX
cherokee
Kansas City MO
You say "not heavy items". I have found it depends on just what those items are.
It is not very often that I solder two wires together, I just don't do that very much. I will solder on different connectors to wire depending if I think a crimp is "good enough". Some things you can't crimp.
I use a great many of these type connectors:
These are popular in the RC world. Holding them with a pair of vice grips *****, a rubber band around needle nose *****. I got a cheapo chinese soldering iron with the arms, works just fine for my needs, but then that is all I do.
I would think if you are using it for other things you could take advantage of the other types of "arms" that are talked about.
I guess I would say, look at your needs, you might not need to spend that much to do what you want to do.....only you really know how you work.
JAYoung
Butte, Montana USA
Make your own: Just solder some alligator clips onto 6-gauge solid copper grounding wire and make as many as you need and the lengths you want.
