IMO spend the $$ ON 4LN, 6LN, or 9LN NOS Petersen Vise Grips on ebay. Made in USA and they will last.I need some needle nose locking pliers. just general grab stuff use, probably 6" and 8-10" sizes. What's good these days? Not chinese is a big plus.
Irwin Vise Grips COO is mainland China, not Taiwan. That said, they are not near as bad as some proclaim them to be. Project Farm's testing has them doing as well or better than several more expensive competitor's products.Bremen sold at Harbor Freight
+1 Irwin Vise Grip
I believe both are made in Taiwan. Both have been good for me
I had a couple of old (late 90s, early 00s) pittsburg needle noses. They were pretty horrible, they had lots of side to side slop in the jaws, which meant they didn't clamp thin things well. They'd hold a nut or bolt, but a washer on edge wanted to flip or fall out as you tightened them. I left one clamped to someone's hood release cable...I bought the Bremen. They seem ok.
Frankly, the cheap Pittsburg or whatever the bargain version is called would have probably been ok. Needle nose locking pliers have a low bar for me to consider them acceptable. I don’t consider them a high stress tool, so as long as I can clamp something in the jaws easily to hold, weld, etc they’re usually fine. I have had some pretty sketchy locking pliers that really don’t perform any worse for my use than my Petersons.
I like the Bremen or the Milwaukee for affordable “new” vise grips. The long nose style is my favorite for getting out a jam so I try to keep a newer sharp tooth pair in the box as a backup.Bremen sold at Harbor Freight
+1 Irwin Vise Grip
I mostly use mine as welding clamps without issue. Incredible as it sounds, I have a few pair from the 70s or 80s from some unknown source that make the cheap HF locking pliers seem like Snapon pliers. They work too. Ugly as sin, but you really don’t need precision or beauty to hold a bracket.I had a couple of old (late 90s, early 00s) pittsburg needle noses. They were pretty horrible, they had lots of side to side slop in the jaws, which meant they didn't clamp thin things well. They'd hold a nut or bolt, but a washer on edge wanted to flip or fall out as you tightened them. I left one clamped to someone's hood release cable...
I bought a couple pairs of the bremens They seemed fine, but as happens, I bought the tool after I really needed it, and haven't needed it since, so they haven't seen much use.
