Forklift Thread - what lift(s) do you have?
bigcreek
Idaho
I didnt see a forklift thread, new or old. Ive always liked forklifts. Ive owned a dozen or so at different times. Some people like cars or trucks or tractors, I like forklifts. I thought it would be interesting to see what forklifts everyone owns or uses. From old to new, junky to wow. I currently own two lift trucks. One Case diesel rough terrain rated for 6000#. The only thing I dislike about this lift is there isnt room to put on tire chains. There is only about an inch of clearance on the inside at two locations between the sidewall of the tires and two points on the truck frame. Id really hate to see a chain get caught. forklifts 008.JPGforklifts 009.JPGVery disappointing because without 4wd chains can really come in handy sometimes in winter around my place. Other than that I love this machine. The Allis Chalmers is a 1980 rated for 6000# as well, gasoline powered. I love this little lift. Great machine, ex military. Ive owned several Hysters, Yale, a couple AC's, and a Case. I liked them all. If I wanted to spend the money Id get a new case 4WD 8000# lift but I dont want to spend that much money so Ill keep what I have. :)
bigcreek
Idaho
here's one I bought for a volunteer group late 2021. a 2009 Cat with mid 4k hrs . side shift forks and 14' or so lift
My case has side shift but not the Allis Chalmers. Side shift is so dang handy, especially when coupled with fork positioners.
bigcreek
Idaho
Here’s a shot of mine actually doing something productive, it’s a 69 or 70 Allis-Chalmers. 054F73CA-9E66-48B4-9D45-B74135BF24BF.jpeg
Wow that Allis Chalmers body style goes right along with that old VW bus in the background. Nice mill. Is that AC a 4000# unit?
gregs
+1 for an Allis Chalmers of the same style. We have a 1972 6000# with a 6 cylinder gas engine. Typical retired military. Its old and ugly but runs almost every day. Had to unload some equipment for the neighboring business because there fancy new forklift was down and waiting to be repaired.
bigcreek
Idaho
AC must have sold the government a pile of their forklifts back in the day because Ive seen a ton of AC units over the years with military tags on them. They made great equipment, too bad they still arent around.
Oregon rock crusher
West of Salem
A good topic for a thread bigcreek. I've had an older 5000 lb Toyota triple mast with sideshift for a few years now and it has helped me take on some pretty big projects that wouldn't have been possible whithout it. There is a thread on forklift attachments in the fabrication section that has a lot of lifts as well as attachments here. https://www.garagejournal.com/forum/threads/shop-made-forklift-attachments-thread.436205/
Here are a few pics of my lift and some of the attachments I made for it. It's done everything I've asked of it including moving and placing 40' high cube containers....one end at a time anyway. It also has the free lift feature that allows it to pass through and lift in low ceiling sturctures. Wouldn't be without it. Ed.
Dan in Pasadena
Pasadena, CA
Love the idea of having one but I have no need of one. IF I got one like the ones pictured above there's no way I could leave it alone. I'd sand it, primer and even if only a (good-as-I-could-do-it) rattle can paint job.
Yeah, I know. It's a heavy WORK tool but it's just who I am. I don't like dirty, chipped up, nasty looking tools.
kyrbz
midwest US
The building I currently live/work out of can't accommodate a forklift. Kinda ***** not having one when when you're in the design/fabrication business. I always told my wife the next place we live I'm going to have a forklift. We recently purchased a new property that was formally a run down plumbing supply business. When we initially looked at the property, they hadn't completely moved out and there was a Toyota forklift in the warehouse. My offer on the property included the forklift staying. I don't know what I would do without it renovating the new property. Additionally I can't wait till I'm done renovating and am actually using the forklift in my new shop. Down the road I also need to give it a little TLC. It's had the side shift swiped off of it. Leaks ATF fluid. The hydraulic hoses could stand being replaced and I'd like to put different tires on it.
bigcreek
Idaho
Great pictures Oregon Rock Crusher. Love how you put that container out like that.
bigcreek
Idaho
Big Joe has been one of the best investments I have made over the years :)
So that Big Joe.. is that meant to ride on or walk behind? Im guessing walk behind as thats a pretty small platform to put your feet and I dont see scuff marks on it. What will that thing lift? And is it the battery behind that cushion door I assume? Man that thing would be great for the small footprint. I just remembered I actually did use a walk behind lift at a facility a year ago to load a 4' shear I bought at auction. It did a great job
BillK
Beautiful Southern Maryland
Walk behind and you have to push it. The lift is hydraulic with a 12 volt battery. Battery and pump is behind the door. Its not cushioned, just sheet metal.
I am not sure what the actual capacity is but I have lifted complete Big Block Chevy marine engines with all of the exhaust manifold etc and its no problem. I imagine they are every bit of 1000 lbs.
mike93lx
Richmond, VA
Would some spacers take care of that? How much clearance would you need?
txvwnut
Bedford, Texas
It's actually a single cab, but yeah Allis has got some curves. The lift is an FC30 with 3 stage mast and side shift.
Yale
Here's my old one that I recently parted with:
It's an early 50's Yale KG51-AT 4000# unit with a Chrysler Industrial 30 (230 ci flathead 6) and runs on gas.
Here's my 'new' one as I found it. It's up and running after a lot of work:
I don't know what year it is - probably 50's? Transitier with a propane Waukesha flathead 4. It's a 2000# unit. I have a thread on here about bringing it back to life but the internet is not letting me access it at the moment for some reason.
Yale
Another double post?
It wasn't like this a week ago.
ATC
VA
I have a skid steer with forks.
The only forklift that would be worth while at my place is a rough terrain model, or a 4WD telehandler. Gravel and dirt.
I've driven forklifts every day for work for the past 17 years though. Yale, CAT, Toyota, Crown....
bigcreek
Idaho
Yes spacers would take care of that. I would want probably 3 inches so a 2" spacer would suffice. I was actually talking about that exact thing with someone just a couple days ago..
bigcreek
Idaho
That Pettibone is wild..
bigcreek
Idaho
I have four two Hysters an H200 and H70, A Mits/Cat FG 25 and a lil Clark Clipper. Here is an old pic of the Hysters, they look terrible but, both have new engines, hoses, clutches tires etc. Both have side shift.IMG_4012a.jpg
Steve
That big Hyster is a beast. Is it rated for 12000# or more? That little Hyster looks similar to my old Pioneer 60 which I just recently sold but its a little different.
bigcreek
Idaho
Currently have a 2013 Mitsubishi.
Has 5’ forks, sideshift and has about a 6500lb capacity.
Love this thing, don’t know how people work in shops without forklifts.
Dang good looking unit. And I second what you said. Ive had people tell me they dont have any use for a forklift. But if you do shop work or live out in the country or do whatever they just have no idea how handy one actually is until they try one out for awhile then they would be hooked.
bigcreek
Idaho
There are some dang good looking lift machines you guys have posted up, Keep them coming I am enjoying seeing these.
txvwnut
Bedford, Texas
When people see my forklift and ask why I have one I tell them so I can lift forks. It’s main duty is to move my trailer in and out since it’s easier than using my truck to since I only have a little over 8 feet of room to work with.
Steve from Socal
Hutchinson Ks.
The big one is 20K, it has picked up a few machines that weigh in the 25K range. The 'small Hyster' is a 7K machine that has done over 10K. The really big loads were machine moves in my shop where the loads are a few inches off the ground. I have lifted some loads at max height and max weight, the difference in how the forklift reacts is profound.
I have done quite a bit of rigging and machine moves, the older forklifts have a lot more reserve lift and counterbalance. That said, I bought a lathe from a shop that had a forklift that could lift it but not counterbalance it without help.20140411_114956.jpg20140411_115355.jpg
Walkers
Cave Creek Az
I have had a late 60s Towmotor, and a mid 70s Cat (Towmotor with Cat badging) with roughly 3-5K capacity. I currently have a Nissan 70. The problem I have now is that I get stuck if I drive over my shadow. This is mostly due to the weight, as it is about 12K IIRC, and my last ones were around 6k. This is used primarily outdoors in dirt. I can’t use it at all if it rains. Ihave considered making some adapters for a second set of drive wheels thinking it would keep me from getting stuck. Do the dual fronts help in that aspect?
bigcreek
Idaho
This dual pneumatic AC actually does really well in the mud and snow. It is absolutely worthless on ice. Unless it has chains then it will go anywhere. The only thing I have to worry about with it is if the mud gets too deep to where it sinks to the frame. As long as the ground isnt too soft that it sinks to the frame then it is good to go. Yes the duals help a ton especially with chains on. However on dry ground if I drive over hard ground that is too uneven the forklift is so rigid it will get stuck because the drive wheels may get lifted off the ground just enough not to get traction. Ive read that duals give a lift ~20% more stability as well which is nice at my place since alot of my place is hilly.
bigcreek
Idaho
Ya those back tires certainly dont look squished in the slightest. Thats a nice lathe.
