Report back on how you like the die grinder. I need to pick one up. It's not an every day use item and I honestly use my Milwaukee angle grinder more, so I just need something cheap.
Will do............It seems like a quality tool and the price was right. It is made in Taiwan, also a plus I think.....................Report back on how you like the die grinder. I need to pick one up. It's not an every day use item and I honestly use my Milwaukee angle grinder more, so I just need something cheap.
Absolutely. The prices on these on the costco site were more competitive than alot of other retailers. I originally purchased a dewalt that put out 8500 from Home Depot but it died t have half the features as this one and it was the same price pre saleI would be super excited if I brought home one of those.![]()
So sorry, I do not understand what you mean by "expand a house full of PEX joints". What does that mean? I have done patch-up plumbing with PEX crimp fittings in recent years, but I have not had to " expand a PEX joint".Because there’s no way I’m going to hand-expand a house full of PEX joints. Also, tubing manufacturer strongly recommends using the powered expander over the hand crank, even though they make and sell the hand crank tool.
Check out pex-a. https://apollovalves.com/article/pex-a-b-or-c-understanding-the-differencesSo sorry, I do not understand what you mean by "expand a house full of PEX joints". What does that mean? I have done patch-up plumbing with PEX crimp fittings in recent years, but I have not had to " expand a PEX joint".
If I remember correctly they refer to Pro PEX made by Uponor as Type A where it expands to accept the fitting and shrinks down to a full flow after a few seconds. The Best way to go if doing PEX in my opinion.Yep. House re-pipe to remove all of the old galvanized, and half-assed copper modifications from the last 70 years.
Google UPONOR and have a look at the pro PEX video, it will become clear to you.So sorry, I do not understand what you mean by "expand a house full of PEX joints". What does that mean? I have done patch-up plumbing with PEX crimp fittings in recent years, but I have not had to " expand a PEX joint".
I’m a (retired) plumber with almost no modern experience in residential plumbing but I do share the same opinion. I’ve never used PEX. Soon I’ll be doing the plumbing on a friends new house so I’ve been researching PEX in great detail. I believe this is the system I’ll recommend to him. I’m doing the labor for free but it’s two hours away so anything I can teach him to do on his own will help.If I remember correctly they refer to Pro PEX made by Uponor as Type A where it expands to accept the fitting and shrinks down to a full flow after a few seconds. The Best way to go if doing PEX in my opinion.
Expanding the pipe to allow a smooth(er) transition between pipe & fittings at the ID helps alleviate my general (albeit ignorant) dislike for PEX. I still prefer copper in most cases and it’s what I used on my house two years ago but I know PEX is a good product in many applications
My last post on this (off) topic…Two types of PEX fittings. You’ve used the “crimp” style, with the rings that crush down on the pipe to compress it on to the fitting. This is the other type, where a PEX ring is put on the pipe, a tool is used to stretch the pipe + ring, and the stretched pipe is put on the fitting. It then tightens itself down on to the fitting.
The expansion type fittings are larger, and flow the same as the pipe inner diameter. The crimp type fittings are smaller, to fit inside the pipe, so restrict flow (slightly). How much flow difference there is is probably a useless debate, but I’m going with expansion.
Crimp is more popular, especially in the DIY space. The crimp tool is relatively cheap and you can get them at any big box store.
Edit: Here’s an expansion (ASTM F1960) connection demo
I have the same wish. Makes me want to buy an engraver, if they made one that put down a strong line. The ones I've seen are always so faint.
Hey, are those Wilde screwdrivers flanking that Craftsman grip driver screwdriver? are they hard or soft grip? thanks in advance,
What’s the advantage over expansion vs copper crimp ring?Because there’s no way I’m going to hand-expand a house full of PEX joints. Also, tubing manufacturer strongly recommends using the powered expander over the hand crank, even though they make and sell the hand crank tool.
"I see, said the blind man". Got it. Many thanks to All.Two types of PEX fittings. You’ve used the “crimp” style, with the rings that crush down on the pipe to compress it on to the fitting. This is the other type, where a PEX ring is put on the pipe, a tool is used to stretch the pipe + ring, and the stretched pipe is put on the fitting. It then tightens itself down on to the fitting.
In general Wirsbo/Uponor expansion PEX doesn't restrict the flow as you expand over the fitting. Plus, AFAIK, there hasn't been a failure of the Uponor fittings. The copper crimp PEX-B has had some failures. I believe it is more due to DIY lack of experience vs a bad system.What’s the advantage over expansion vs copper crimp ring?
Those have been hit or miss in my local area in terms of who had them in stock. The website shows who has them. My local store never has the flush cutters in stock and so far I have bought the 7” cutters and the fuel pliers. I just buy them as the coupons come out.
Fed, yes they are Wilde. They are a firm grip with a soft texture. The shape is very similar to the Snap On instinct.Hey, are those Wilde screwdrivers flanking that Craftsman grip driver screwdriver? are they hard or soft grip? thanks in advance
