^ can't remember exactly what we did to get it out but we could have used that widget on that Ford truck last summer when replacing the side glass.
Unfortunately I can't help there as I am in Australia and ordered it from within the country.i need that for work, going to order it today did you get it from amazon japan or somewhere state side?
ustoolhub.com
kokenusa.com
palmac.net
Reliable USA sources for Koken tools:
Window Molding Remover Length 210mm - Ko-ken USA
Length: 210mm Product Dimension (Refer Line Drawing Image): H Size: 100mm L Size: 210mm - Ko-ken USAkokenusa.com
Ko-ken Tools Window Molding Remover Length 210mm - Palmac Tools
Length: 210mm Product Dimension (Refer Line Drawing Image): H Size: 100mm L Size: 210mm - Palmac Toolspalmac.net
KokenUSA prices include "free" shipping, Palmac charges separately for shipping.more like source... singular.
same source, different pricing![]()
Wow a bit on the expensive side, $40 and $52?more like source... singular.
Yes, use mrsubaru10 at Kokenusa for 10% off.nice, never noticed that. that is possibly worth it for small orders. all my palmac orders have been big enough to get free shipping, so i didn't notice before.
is there a permanent coupon for kokenusa like on palmac ('mrsubaru5')?
Thanks for sharing, good information!A quick review of my Anex 3775 driver which i bought over 2 years ago from Amzn.jp
I use mine for automotive and household work and enjoy using it. The shaft to handle tolerance is excellent and there is no free play while using it. I often wondered how the inside of the plastic handle was made to manage torque being applied on the blade and found that there is a metallic portion in which the blade engages, this is good design and has held up well with my usage. I have also used the handle with shorter Wera, Vessel & Trusco bits and they perform well with the only issue being that the ball detent position does not match (obviously) but the ball detent of the Anex bit does not match with the handle either so i guess i've got nothing much to complain about.
Overall, i like this driver very much but i'm unaware of any torque ratings for it. The handle is shaped well with a partial soft grip which is my only concern. While using it in narrow spaces with sharp corners (say sheet metal and confined engine bays) the soft handle material has taken several cuts / nicks over the years - Not enough to damage the handle or to take chunks of the soft material out but the cuts are visible when dirt, grease and grime gets into them. There is also noticeable amount of wear of the soft handle material with my occasional usage so i'm guessing in a heavy use environment it may not last long. The handle washes up very well with just soap water and has also held up well against automotive fluids like coolant, gasoline, various greases & oils etc so far.
Looks great, care to share where and how much please? Thanks
National Tool had them. Unfortunately they're OOS. I paid $32 shipped.Looks great, care to share where and how much please? Thanks
Super cool...I'm the same I was on AmazonJP again and filled my cart up with 93 itemsThe Anex is my current favorite ratcheting screwdriver. My fumbling fingers inadvertently turn the direction ring of the Vessel too often. The PB Swiss has the ratchet in front of the handle, and it ends up feeling sort of like the Frankenstein thing at the bottom of the photo, luxuriously smooth but heavy and imbalanced.
...and when I spend idle time on Amazon Japan I often end up with nice looking things I might never need.
When only buying a single Koken tool, it can be cheaper to buy from KokenUSA, in my experience. The minimum shipping charge at Palmac seems to be around $11.50.i was bored, so i spent 5 minutes recreating my most recent palmac order on kokenusa.
palmac:
kokenusa:
- subtotal: 755.14
- total (-5%): $717.37
so they priced my order about 23% higher (after coupons) on kokenusa. not a surprise.
- subtotal: $980.79
- total (-10%): $882.71
palmac ships free over $199, so i guess it could be worth comparing if your order is less than that.
how much was shipping if you don't mind me asking? In the US that would be $380 in shipping costs from Amazon Japan.Super cool...I'm the same I was on AmazonJP again and filled my cart up with 93 itemsand checked out. I bought a few more 397 Anex and 3 of the stubby versions. And the older red 60T versions. And a whole bunch of stuff. A good steal was the Koken 4pc thin wall wheel socket set 17 19 21 & 22mm for $21au. Probably like $15US. That set sells here for like $145! I found they were a bit low on stock and wouldnt ship certain items that didnt make sense. I wanter the Tone socket adapters you put in a box end wrench and they wyer all in stock but they would only allow me to order the RA1 which is the 1/4" one and not the RA2 or RA3 3/8 and 1/2. I hope the Annex ball grip screwdrivers are close in quality to the Vessels as I have 1 or 2 on there way. U chose well the purple strike through Vessel is 'made in Japan' where as the yellow and red ones can be 'made in Thailand'.
Very Nice! Quite also, thanks for sharing.SP Air Hex Driver
I spent about $950-1000 on products and shipping was about $200. I made sure to only buy 'in stock' products from Amazon JP believing that if they all come from the warehouse they can bulk ship and reduce cost. You have to buy id say at least 10+ items to make it worthwhile otherwise a $5 item will have $30 shipping lol. My last order was delivered by DHL. Now this is in AU dollars so USD would be roughly equal to USD$75 equals $100aud. Shipping is the BIG consideration and you have to almost chechout before you know what the total is.how much was shipping if you don't mind me asking? In the US that would be $380 in shipping costs from Amazon Japan.
Thanks for the detail and the data points. I can stomach 15-20% shipping costs.I spent about $950-1000 on products and shipping was about $200. I made sure to only buy 'in stock' products from Amazon JP believing that if they all come from the warehouse they can bulk ship and reduce cost. You have to buy id say at least 10+ items to make it worthwhile otherwise a $5 item will have $30 shipping lol. My last order was delivered by DHL. Now this is in AU dollars so USD would be roughly equal to USD$75 equals $100aud. Shipping is the BIG consideration and you have to almost chechout before you know what the total is.
Here's an example of the screwed up Amazon Japan shipping algorithm for us in the states - 45% shipping costs:
Temporarily out of stock.
We are working hard to be back in stock as soon as possible.
Ships from
Amazon.co.jp
Sold by
Amazon.co.jp
Yeah but your dealing with local US amazon that will offer products from Japan through that system BUT....go check the prices in Japan Amazon & the price could be a LOT better. But you then need to consider shipping, import fees etc. Its a juggling act.My wife has the Prime account with Amazon.com, so I have her order all my stuff. The last tool order she made for me was an Anex 397 driver and an Anex bit kit. Both made in Japan. The 397 was a regular Prime item but the bit kit came via Amazon Japan.
I think Koken makes THE best tools for this type of situation. They dont just copy others, they invest and innovate in this area.Had a tight spot yesterday - needed to remove the nut from a solenoid to add another hot lead. A tight spot, and the plastic barrier between the solenoid posts didn't help. Could only barely get my fingers back there to pop the red rubber cap off the nut, and the only wrench I could get on it was an offset 10mm that I could only get 1/12th turn on. Really pleased with the little 1/4" Ko-ken ratchet, wobble extension, u-joint, and nut-grip socket.
I did *not* want to drop that nut into the narrow abyss, so the nut-grip added a lot of assurance. The negative terminal (in front) was a lot easier!
