quakerj
I had a 16'W x 10'H garage door installed in my 30x50 red iron building. Installer had to use a double track low front clearance kit due to the rafter at the front of the building not giving enough clearance for the torsion shaft/drum assembly.
I have enough clearance above the shaft/drum that a jackshaft / wall mounted operator will fit cleanly. But the Liftmaster 8500 documentation says it will not work with a double track / low clearance door. The cable off the drum comes out on the inside of the building, not outside as would be typical for most doors. So I think the shaft spins in reverse direction for open/close. Is this a deal breaker for wall mounted / jackshaft type opener?
If so, can someone recommend a good overhead opener (would really prefer not to go this route) that would be durable and long lasting, opening a 16x10 door? Any input/suggestions would be most appreciated!
