kobaltic
I got my first garage. It came with an in ground single post floor lift. It is a rotary lift. I have some questions about it. I think it is from the 60's. It is air over hydraulic. I had to get an air compressor. I got an 80 gallon, 175 PSI from tractor supply.
https://www.tractorsupply.com/tsc/product/ingersoll-rand-5hp-air-compressor-80-gal?cm_vc=-10005
The lift will go up although it took 5 minutes to raise my car one foot. Then the fun came. It took 30 minutes to lower my car one foot. There is a picture. I did clean up all the loose rust and dirt. So here are some things I am trying to figure out. Thanks in advance.
1. Where can I find the model number or information? The air line handle says rotary lift Memphis. I don't see anything on the lift. Trying to find a PDF or a place that I can order parts.
2. I think the slowness issue is the hydraulic fluid. There is a cap in the middle of the shaft. Is this where I would check / remove / change the fluid?
3. Is the center cap a plug or a cap? It looks like a plug but I see threads at the bottom so I think it is a cap.
4. The cap is completely rusted. Looks like someone drilled some holes in the cap loosen it (the holes do not go into the threads). Any thoughts on how I can get this off? I tried WD-40 and channel locks. I am getting the correct size wrench (I think it is a one inch) and most likely a three foot steel pipe for leverage. Although I am nervous about breaking it.
5. There is a pole in the ground next to the shaft. I understand that is to stop the rotary action and also use as a jack stand to prevent the lift from coming down in a failure. How does this lift up? I thought I would just pull it up by hand but it doesn't budge. I also WD-40 around the casing to no avail.
