Well after i thought i had this solved completely i didn't . I only had low speed and reverse connected when i tried it.When i hooked the high speed connection on neither would work.If i disconnected high speed the low speed and reverse would work and the same if i disconnected low speed the high speed and reverse would work Huanyang who was also helping and showed me wiring and parameters now saysI got the speeds of my table from Hunter's brochure I found online. Reverse and high are 15 rpm and low speed is 7 rpm. I bought a little photo tach that worked on the motor. On the actual table, I just marked it and timed one revolution and then played with the frequency to get those speeds.
I missed this earlier. I agree, basically jumpering S1, S2 and S3 together isn't going to work. The OP needs to fine double pole micro switches, or find some other way to isolate the control wiring.I think your high speed switch is getting a signal from S3 when theblow speed awitch is made and vice versa. So it sees s1 and s2 high at the same time. If you remove the connection to s3 from one speed, does the other work? If so, you could use 2 diodes to get the signal from S1 to S3 for low and one from S2 to S3 for high speed.
Nothing special as there is not real power on the control side. What ever you can find should work.i may try the diode trick .Any certain size of diode you guys would recommend?
Bit confused .Where would i put the 2 diodesI think your high speed switch is getting a signal from S3 when theblow speed awitch is made and vice versa. So it sees s1 and s2 high at the same time. If you remove the connection to s3 from one speed, does the other work? If so, you could use 2 diodes to get the signal from S1 to S3 for low and one from S2 to S3 for high speed.
Well, then you know the control wiring is screwing it up.yes both speeds work if you disconnect the other
Yes, you might find them elsewhere for a better price. I just looked on Amazon.So i need 2 of those switches and these replace the 2 that are on the foot pedal for high and low that are there now?
Just jumper the S3 from switch to switch.They don't look too expensive like 5 for $12 i guess i would have to run another wire from S3 back to the switch
Doesn't look like any of those switches would work they are all SPDTWell, then you know the control wiring is screwing it up.
IMO, you need to go with something like this,
https://www.amazon.com/dp/B005T7E1JA/?tag=atomicindus08-20
This switch would allow you to isolate the COM, S1, S3 and the COM, S2, S3 dilemma. Wired like this there will ber no cross connection.
The link shows a DPDT switch. The factory switch on the Coats tire changer is SPDT.Doesn't look like any of those switches would work they are all SPDT
It's all good .I have checked this several timesI would check for continuity from s1 to com and s3 to com @ low speed and s2 to com and s3 to com when the high switch is made. Also, make sure there is no continuity between s1 and s2 @ any switch position. When the pedal is released, there shouldn't be any continuity from S3 to any other lead.
Then it seems it has to be something in the settings. I'll look through your manual and see how similar the parameters are to mine.
These are currently the only parameters i currently have .Which parameters should i be putting in to match what you said to try?Looking at the chart on p. 69, I would try to use stage 5 (S1,S3 high) and 6 (S2,S3 high) for your 2 speeds instead of stage 1 and 2.
I will admit, I a confused.Looking at the chart on p. 69, I would try to use stage 5 (S1,S3 high) and 6 (S2,S3 high) for your 2 speeds instead of stage 1 and 2.
Sure, but you still need to close S1, S3 and S2, S3. The problem is with the wiring from the control switches. Perhaps I am missing somthingPA.04 is multi speed step 1 and PA.06 is step 2. When switch s1 and s3 are made, the chart indicates to use stage 5. I interpret that as step 5. So, I would switch PA.04 for PA.12. I would switch PA0.6 for PA.14. I'm just guessing and I've never played with a vfd before the one I put on my machine. The defaults on those are 0, so it would make sense that it wouldn't run. Does the display show the commanded frequency?
Correct but how do you energize S1 S3, and then S2, S3 with single pole switches and keep S1 and S2 isolated???I'm just guessing.... but it has 2 made switches so it looks at step 5 for the required frequency. The default frequency is 0, so it shouldn't run.
How does this clear that up?
He used diodes. Checking continuity for each switch position it sounds correct to me.Correct but how do you energize S1 S3, and then S2, S3 with single pole switches and keep S1 and S2 isolated???
I don't see where that cures the wiring problem.
